I have a Logitech z-5450 wireless 5.1 speaker system. The center speaker has cracking, static noise, wireless rear speakers OK, right and left Ok, just the center speaker, swap speakers, same on center channel when put into prologic II decodeing. Stero mode OK, because nothing come through the center. Volume does not increse the static noise, the static noise is constant, so, if the master volume turns louder, it drown out the static somewhat, but at listening level it is annoying.
  • 677 Answers
Hi, If the speakers are not powered speakers then it is not from the speakers.But if the speakers are powered, then the sound IC is bad and needs to be replaced.
Try and troubleshoot your connecting cables,it will be fine.
Take care.
Posted on Jul 14, 2010
Z-5450 rear wireless speaker not work always red light flashing
Hello have you been able to fix the problem. Do you still have the speakers?
Sep 12, 2011 | Logitech Z-5450 Computer Speakers
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
I have a new samsung home theater system w/ wireless rear speakers. all of a sudden the rear speakers now have a static/cracking noise. ive checked the connections and they all appear good. i dont know...
Move the wireless speakers up to the main system box and see if they work OK with an almost touching signal - it could well be interference between the player and the speakers.
Test them at the front and get back to us.
Feb 25, 2011 | Audio Players & Recorders
My rear speakers do not conect further than 1m away from the main unit. How do I solve this?
you would have to get a sronger wireless device for the speakers get in touch with logitech to see if they have one.
Feb 19, 2011 | Logitech Z-5450 Computer Speakers
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
My logitech z-640 speakers arent working and i have no clue why first id like to know where to plug in the plugs in my laptop theres a geen,orange,black cord i have a microphone,headphone and some other...
The different connectors are for 5.1 surround audio, and are for different speakers with your system.
  • The green connector is for your front-right/front-left speakers
  • The black connector is for your rear-left and rear-right speakers
  • The orange plug is for your center speaker.
Most laptops do not have support for 5-speaker audio, so if you want to test each individually, you will need to plug them in one at a time and test playing sounds through them.
Hope this helps,
Dec 17, 2010 | Logitech Z-640 Computer Speakers
My right rear does not work and i have test averthing. what should i do now? Logitech z5450
mcdevito75 here, There should be a volume control on either the left or right speaker, maybe both, check the volume control on both speakers. also the connections to your computer.
Jun 22, 2010 | Logitech Z-5450 Computer Speakers
Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
May 30, 2009 | Logitech Z-5450 Computer Speakers
I had a problem with flashing red on speaker. Yes, i repair it! it is very simple - you must only change 2 condensers 100uF 10v in speaker. It WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 27, 2008 | Logitech Z-5450 Computer Speakers
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
64 people viewed this question
 Grubhead
Grubhead
