Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
I would like to be able to remove a link from my chain saw chain
    Brigadier General:
  • 4,088 Answers
Take the saw to a servicing dealer who will have the necessary riviting tools to shorten the chain (and will properly advise you if extreme chain wear is the reason you need to do this). Good luck!
Posted on Jul 07, 2010
4 Suggested Answers
tripletauto
  • 1450 Answers
SOURCE: how to determine chain size
the 16" has 54 links
this should be part number
McCULLOCH16" REPLACEMENT CHAINSAW CHAIN 91V-54
Posted on Oct 15, 2008
SOURCE: how do i remove links in my power saw chain to
Yes they sell links for that at the saw shop. You file the head off two rivets in the chain to remove however many links you need then install the connecting link. If you're not sure how many to remove, take out one at a time putting the connecting link in without bradding the rivets. Put it back on the saw and see if its still too long. When the length is right you brad the end of the rivets that come with the new link.
Posted on Mar 08, 2010
Editor925
  • 285 Answers
SOURCE: I have a remington 18
You need specialized workshop tools to break a chain, and another tool to rejoin it (Chain Breaker, Chain Joiner). These are quite expensive items and costs more than a few new chains each, so it is probably more cost effective to get a new chain. It is odd the current chain has stretched that much. perhaps it had one too many links to begin with?
Posted on Feb 25, 2011
Testimonial: "Thanks for your help. I had a feeling that was the case. Years ago all it took was a screw driver and needle noes pliers to do the job."
Chain won't move after chain replacement
Had this happen to mine when I was limbing stuff that was too small. I know better. There is probably a burr on one or more of the guide portion of the links where they run in the bar. This causes that link to be tight in the bar at this point. The chain probably hit something on the body of the saw when it flew off. Take the bar off the saw and run the chain through the groove in the bar. If you have any links with nicks, they will bind, causing the chain to stick and not run freely. Once you've identified the problem links you can remove the nicks using 120 grit paper backed up with a flat piece of steel so you only remove the high spots.
May 05, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to change a chain
First of all, make sure the saw is off. Also, before removing bolts, make sure the chain brake is not engaged (the chain should move freely).
Remove the guide bar side panel. Using a scwrench or wrench, unscrew the nuts and remove the plate to access the chain.
The side plate on most chainsaws will be held on by two nuts. Loosen the blade adjustment screw (a pin that is usually driven by a screw and pushes the blade out from the chainsaw to keep the chain tension tight).
The old chain is ready to be removed now that the sprocket plate is off of the saw. Pull the nose of the chainsaw's bar away from the chainsaw to release it from the tensioner.
Remove the old chainsaw chain.
The chain will easily remove from the guide bar with all that slack in it. Note the orientation of the cutting edges of the chain so you put the new one on the same way.
Pull the drive links out of the guide bar and slip the other end of the chain around the clutch drum.
Steps to Install a New Chainsaw Chain
Thread the new chain onto the saw.
Carefully thread your new or recently sharpened chainsaw chain around the chainsaw's clutch drum, making sure that the drive links engage in the sprocket.
Thread the rest of the drive links into the guide bar and around its nose, making sure all links are in the guide bar slot.
Align the guide bar.
With the chain properly threaded along the clutch drum and guide bar, put some tension into it by pulling on the nose of the guide bar away from the chainsaw.
While pulling the guide bar, make sure to seat it onto the saw's adjustment pin.
Replace the side plate.
The side plate is ready to go back on as long as the guide bar is properly positioned beneath.
Replace the plate and the nuts that hold it into position, but do not tighten the nuts down all the way yet. The guide bar must be allowed to move a little while the chain is tightened to the correct tension.
Tighten the chain to the correct tension. Use the tensioning screw to the side of the guide bar to adjust the tension on the chainsaw chain.
Finish tightening the side plate nuts.
The chainsaw chain replacement is now complete.
And here is a great overall reference guide to keeping a chainsaw sharp and running. Sharpening a chainsaw chain is a great way to extend the life and is less expensive and easier than replacing a chain. There are small grinding tools (like a dremel) that can be run off a small 12v battery or your vehicle battery that allow for quick 'tune-ups' on your chain if you are out cutting and need to sharpen your chain.
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Aug 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Mar 14, 2011 | Craftsman Garden
How to change the chain on chainsaw
Most saws are pretty much the same procedure.....here's a decent link. Some saws will give trouble if the brake is on when you remove the side cover so make sure the chain moves freely before removing the side cover.
Here's one on tensioning the chain...
Dec 07, 2010 | Homelite ZR10926 16" Chain Saw
How do i remove links in my power saw chain to make it the proper size.It's a new chain that's the right size for the bar .073 but is too long. I have an Oregon chain break and a shop to do it in. Do I...
Mar 07, 2010 | Husqvarna Garden
Chain replacement.
Input "M12510US" in the model number here (if not your saw the procedure should be similar):
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
See pages 7 through 9, for use as a guide.
HTH
Lou
Are you aware RemingtonPower is no longer in production? Replacement parts are becoming difficult to find.
Jan 23, 2010 | Remington Electric Chain Saw
The chain came off of my Remington 16" electric saw. How do I put the chain back on?
If the saw was at speed when the chain came off there are probably burrs on the chain drive links (the part that goes in the bar). They often cause binding and in extreme case may cause the chain to ride up and off the bar when operated. Use a file on the drive link flats to remove all burrs.
An Operator Manual far almost all models of RemingtonPower chainsaws can be found here:
Remington.com
HTH
Lou
Dec 28, 2009 | Remington 16" Electric Chain Saw
Saw will not cut , chain stops turning when chain touches wood
If your saw has a removable sprocket, Check the drive sprocket on the clutch drum. Either the the spline is worn or the drive link on the chain is not properly seated in the sprocket well.
Apr 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 345 chainsaw chain doesn't move freely and heats up
has the chain ever came off the saw?and i'm going to assume that it is the correct chain for the saw...reason i ask about the chain comming off the saw is that when it does the driver have a tendency to become nicked and will heat up the clutch because the saw is trying to drive the chain links through the chain slot.also you need to look at the drive sprocket to see if there is any wear on the teeth....also over tighting the chain will cause the clutch to heat up.
Feb 22, 2009 | Husqvarna Garden
14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Sep 27, 2008 | Remington Electric Chain Saw
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
224 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
