Question about HTC Touch Diamond Smartphone
Loss of touch screen function on Imate 810F
I have a fairly new Imate 810f smartphone. I had some problems with a faulty charging cable which caused the unit to only partialy charge. Then the touch funtion of the screen stopped working. I have carried out a hard reboot but the touch function still does not work leaving me at the green windows message :Tap the screen to set up your Windows Mobile based device''
I would like to remove and refit the battery but do not know how to open the case.
Any help gratefully recieved.
  • Guy Davies Jul 07, 2010
    Thanks I have opened the phone, the battery appears to be contained in a metalic envelope which seems adhered to the phone chassis. there are three wires exiting the battery but they are very short and appear to be soldered to the circuit board.
    Can the battery be lifted off the chassis? it seems very well fixed. How would you disconnect/reconnect the battery?
Hi
How yo perform the hard reset? the rear button is just a soft reset.
Well, you can open it removing the 6 gray ruber cap covering the bolts in the back cover. Under those caps you ll find 6 star bolt heads covered with a white seals, remove the seal, unscrew the bolts an open the phone inserting in the line your thumb nail or similar tool.
you ll find the battery attached with 3 wires. this connect and reconect it.
Posted on Jul 07, 2010
Testimonial: "Helpful information thanks! Have now opened the phone without damage just need to work out how to remove the battery which appears to be glued down"
I need to unlock my computer because everytime i leave my computer unattended i have to type i my password i wish to undo this. can you help?
have a look in your screen saver settings, there is a tickbox which says "On resume, display logon screen", untick this box and click apply, this should sort your problem.
May 05, 2011 | Computers & Internet
I have bought a Imate 810F....But it was louded with the chinese version of windows 6.1.....is there a way in which i can change it to an english version of wondows? Please help me, because i really...
You can only change the language by applying an English ROM and the latter can be obtained from the device manufacturer or the reseller. In any case, if there is one available, you will find it on their website or you may try your luck by asking them to re-flash your device.
Or, you could try to do the following but I doubt it would work:
  1. Click "Start" to access your start menu. Scroll down and select "Settings."
  2. Scroll down and select "More" until you see "Regional Settings," and click on it. The icon should display a planet image.
  1. Select your language and your locale (optional). Setting the locale will display the date and time in the proper regional format (Ex: 21/3/2009 or 3/21/2009).
    Click "OK" to confirm. Reset your device for the changes to take effect.
Mar 16, 2011 | Computers & Internet
Asus k50ij webcam image upsidedown
I have the same problem with my laptop Asus K50IJ, and apparently we're not the only ones. It seems that the only solution is manycam.com, as lifeframe utility or driver installations don't solve anything. Hope it helped!
Jan 30, 2010 | Computers & Internet
Mate Jama shows only blue screen.
i tried to update my Imate JAMA's rom to WM6, while i was updating my phone it went power off as it was out of charge. now the problem is this i cant switch on my phone, it dont even shows the blue screen, even my battery i fully charged. Is this because my Imate's ROM? which i was trying to upgrade? I need a solution plzz
Jan 07, 2010 | i-mate Jama 101 Smartphone
IMATE JAMA touch screen not working
hi thanks for using fixya!!
I am sad that the Imate Jama is not providing much use to you. However, it will be a useful one if you are going to explore its functionalities.
Anyhow, in regard with your problem, we cannot do anything with it, the only recommendation I could tell you is to bring your PDA to a service technician to further check the hardware error of it especially the touch screen does not working properly.
Regards!
May 21, 2009 | i-mate JAM Pocket PC
Touch screen not working
   That's the main problem with most of the touch screen.
In case, if it's not working, you need to replace that ( In case, you are sure you haven't played with settings )...
Reset the phone - Factory settings.
In case if the issue would be there, confirmed faulty touch screen. If under warranty, get that exchanged unless buy a new touch screen.
Go for original touch screen setting unless might cause this issue again.
Thanks for using Fixya.
Apr 23, 2009 | ASUS P527 Smartphone
Batery
I experienced the same problem. Only 2 days after purchasing my new HTC Touch HD handset, the battery went flat and could not be charged. The phone, the USB cable and charger were all functional. I had to return the phone to the retailer (TELSTRA SHOP - AUSTRALIA) who concluded that the battery was faulty, but I was told the entire phone had to be returned to HTC AUSTRALIA as the retailer would not replace the battery. I was told it might take several weeks for the problem to be resolved.
After a little negotiation, the retailer finally agreed to replace the entire phone. My new HTC Touch HD phone works well and I have had no further battery charging problems. You are not alone. Don't despair. It is just a faulty battery.
Apr 15, 2009 | HTC Touch HD Smartphone
Broken touch screen lcd glass cover
Yes you can find the glass on Ebay and there is an iphone glass replacement guide online that shows you exactly how to replace the glass.
Jun 08, 2008 | Apple iPhone Smartphone
Canon FB630u problem
I have struggled with this same issue for ages, I just found a fix from the HP site for the same problem with an HP scanner - it worked for my Canon LiDE70. Run regedit then:
  1. Double-click HKEY_LOCAL_MACHINE to open the folder in the left pane of the window.
  2. Double-click SYSTEM , CurrentControlSet , Control and then Class .
  3. Select {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} and check in the pane on the right for the Lower Filters string value.
  4. Right-click Lower Filters and delete it.
  5. Disconnect the scanning device and restart the computer.
  6. Reconnect the scanning device after the computer is restarted.
  7. BINGO! it worked!
Feb 13, 2008 | Canon CanoScan FB630U Flatbed Scanner
HTC Touch Diamond Smartphone Logo
306 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
