Question about Datamax I-4308 Thermal Label Printer
Datamax i4380 software lost
Dear Datamax:
This is ATI wireless ,I'm Ping.(email: atiusa_tech@hotmail.com)
Befor we bought datamax i4380 label printer, but we lost CD. and now, we want exchange new computer, we have download it's driver Datamax_7.1.3_M-1 (size:6989KB) in your website, after install it in new computer, but no priter icon that can edit label windown.
we need some support software? please tell us, where can download that?
  • 27 Answers
SOURCE: Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Posted on Dec 30, 2008
  • 54 Answers
SOURCE: datamax dmx-m-4206
check for the flatness of the printhead across the platen.
also check to see if the head is not worn(will be white colored at the head heat elements.
also check to see if the platen is severly worn.
Posted on Feb 25, 2009
Nic61
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
bartech9
  • 155 Answers
SOURCE: vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
Posted on Jun 10, 2009
bartech9
  • 155 Answers
SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Zpl emulation with datamax i-4208
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
Datamax DMX E4203 Printer driver
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Aug 19, 2012 | Datamax DMX E4203 Printer
Do you have downloads for Datamax Drivers? Mainly, E-Class
Free Windows Printer Drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Jun 09, 2011 | Datamax M-Class Thermal Printer
Datamax i -4208 printer
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Nov 24, 2009 | Datamax I-4208 Thermal Label Printer
I need driver for datamax m 4206 e mark II
Jun 16, 2009 | Datamax M-4208 Thermal Label Printer
Problem with old datamax printer.
It sounds like you may not have the latest firmware. You should go to the Datamax website and download the latest firmware revision for your printer. http://www.datamaxcorp.com/software/ If it's not available on the website, you can call Datamax with your CID# and serial number and ask them to send you the latest firmware for that printer. This should hopefully clear up your problem.
Thermal Printer Repair @ Worldwide Ticketcraft
http://www.worldwideticketcraft.com/printers
May 22, 2009 | Datamax DMX-I-4208 Label Printer
Visual Basic 6.0 Code for Datamax ST3210
In www.datamaxcorp.com can find the programming manual of printers and you'll find examples of label design.
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Printer.
I have seen quite a few bad nic cards from Datamax, and that may be the problem.
If you can set the card from the printer, then it is seeing the card as it reads directly to the processor when inserted. But the card can still be bad if you cannot ping from the outside.
Jan 12, 2008 | Datamax M-4208 Thermal Label Printer
Datamax I-4308 Thermal Label Printer Logo
61 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
