Question about Univex 373 Watts SRM20 Stand Mixer
How to connect univex dimmer - Univex 373 Watts SRM20 Stand Mixer
How do I trouble shoot a 7512 slicer to free up a frozen slide arm?
There's a Carriage Arm Knob that has to be loosened that could be a possibility also your supposed to lubricate it weekly with mineral oil.
Sep 26, 2015 | Univex Duro 7512 Slicer
The cord has a short and I need to replace it
Hi, this is a very simple process. I don't know if the cord is a 2 prong or 3 with the ground, but it makes no difference. You should have screws around the perimeter of the mixer that you need to take loose to separate the half's. I am assuming the cord is built into the mixer, if not please correct me. The end of the cord will be connected to the on/off control, may it be a trigger type or slide or what ever it has. You will have either a black wire which is hot, connected to the switch so the switch can break the connection to turn the mixer on and off. The other wire may be white which is neutral connected to another wire in the mixer, you will see this. If it has a ground, 3 prong, it will be green and will show you where it connects. If it is just 2 prongs, the 2 wires may both be black and in this case you can connect them to either wire they are showing you. I don't believe the connections are soldered, they may be screw connections or wire nut connector's. If it would be easier for you, take the mixer with you to your hardware store such as Home Depot as they have many different cords to choose from, and you will get help in the electrical section to make sure you have all you need. Just take your time and put the wires back in the same way as the old cord was wired. If the cord is a detachable cord, take it with you and match it with one that has the same connections and 120 volts. You do not have to buy a Black and Decker cord to do this. There are many cords that will do the job just as good if not better. Keep me posted if you need my help.
Sincerely,
Shastalaker7
Feb 12, 2010 | Black & Decker Ergo EHM90 Hand Mixer
Starts on high speed and quits
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Dec 14, 2008 | KitchenAid K45SS Classic Stand Mixer
Mixer speed turned erratic!
Nov 22, 2008 | KitchenAid KSM50PR Professional Series...
KitchenAid 350 Watts KSM50PR Professional Series Stand Mixer stuck on
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Jul 25, 2008 | KitchenAid KSM50PR Professional Series...
Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
Univex 373 Watts SRM20 Stand Mixer Logo
228 people viewed this question
Top Univex Food Mixers Experts
eyecam
Are you an Univex Food Mixer Expert? Answer questions, earn points and help others
