Question about Briel ED271AP 10-Cup Multi-Pro Espresso / Coffee
Coffee side died in my Briel ED271APG
The light comes on but does not heat the water. Put a multi-meter on it and have continuity thru the heater coil and the thermostat. Could it be the switch ??
  • 518 Answers
Well if the rest is okay then the wiring or the switch is suspect
Posted on Jul 07, 2010
Briel Multi-Pro problem.
The head gasket needs to be replaced or cleaned.
Jun 19, 2010 | Briel MultiPro Espresso Maker - Brushed...
No hot water can't even take a shower
If there is only cold water coming out from the water heater, there is no doubt that your RTO water heater
is defective.
1. Shut the power supply going to your heater off.
2. You can check on it, by opening it up.
3. Trace the wires coming from the power supply.
Using a multitester, check the continuity of each
line. Set the tester to Ohms 1 x 10. Put the multi
tester probe to each end of the electrical line, one
line at a time. The pointer must point to zero.
Otherwise, it must be replaced.
4. Test the heater coil for continuity. One of the multi
tester probe must be placed at the common termi-
nal. Put the other probe to the other terminals. The
pointer must be at zero, otherwise, you can
replace the heater unit, since this is already
busted.
Nov 24, 2009 | RTO American Heat Tankless Electric Water...
Water forced out around seal when making espresso.
1- Try cleaning the seal with a group brush if you do not have one you can get a hard toothbrush this will clean the coffee grounds on the seal, if the problem still occurs then the seal needs to be replaced.
Apr 26, 2009 | Briel Multi-Pro ES-200A Espresso Machine
Coffee will not brew, heating element does not seem to work
You either have a bad thermostat,heating element,cord, or limit.If it was me I would check each component with a meter for continuity. Get a cheap meter that beeps when you touch the 2 leads together. This is continuity or a continuous circuit. One of them things I mentioned is kaput. This is not rocket science. Limits can be bought cheap. Let me know what you find out.
Mar 23, 2009 | Briel Sintra ED-132 Espresso & Coffee...
Briel MultiPro Series The machine suddenly stopped heating. Everything works fine except that coffee comes out cold. There is no way to heat up water. Which part could be deffect?
Possibly bad heating element which is inside thermoblock. Can purchase for $75. Contact Fank at ElectraCraft Phone (201) 439-1700 to help you troubleshoot.
Mar 15, 2009 | Briel Multi-Pro ES-200A Espresso Machine
No hot water flowing thru faucets
check the temp setting on hot water heater
if it is electric and 2 elements one could be out
You will have to take a multi meter and check continuity on elements
Purchase new element and replace
if it is gas increase tem
Jan 09, 2009 | Samyang Phoenix Faucet Shower Valve
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Briel Multi-Pro Coffee / Espresso Maker
You have a leak in a connection or maybe the boiler. There is nothing you can do but find a repair shop to fix or replace the bad part.
Jul 30, 2007 | Briel ED271AP 10-Cup Multi-Pro Espresso /...
Briel ED271AP 10-Cup Multi-Pro Espresso / Coffee Logo
126 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
