Question about LG LSC121PMA Split System Air Conditioner
Whenever we switch on the ac after 5 to 10 mins water starts leaking from the indoor unit front side.
    Problem Solver:
  • 12 Answers
Most likley your airco needs servicing.there is a condensate drain off on the outside where the copper piping comes out the wall,if after the 5 to 10 mins no water comes out through there it could mean that the drainline is choked..also u can check to see if your evaporator is graded properly to ensure a proper drain out of the condensate:-)
Posted on Jul 07, 2010
How do i do when the indoor unit start water leaking non stop??
Water leaking depends on 18 reasons. Plz let me be cleared that voltage, amphs, gas pressurer, indoor motor condition, cleanliness of the indoor evaporator coil., etc.
Sep 20, 2014 | Heating & Cooling
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
Model: KFR-32GW/Ac Will not stop leaking water from the front of the unit. Coils have no ice. Shut off unit for 30 min the leaking stops but resumes when AC is turned back on.
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Aug 08, 2010 | Heating & Cooling
Water leaking from indoor unit after 30 mins use
The drain tray has a blockage. Easiest fix is to lift the front facia panel & get someone to hold a towel at the bottom right hand coil where the air filter normally sits. Then blow up the condensate drain from the outside.
Jun 29, 2010 | Fujitsu 24R1 Air Conditioner
Control unit not working - blinking
i dont really understand, but if it a residential split and you have water in the emergancy pan underneath the indoor unit there is a float switch in that pan that is open not letting the unit come on it is there to prevent water from leaking throgh the ceiling.
drain that pan and unit should come on however something is wrong. when is the last time yuo changed the filter 9 times out of ten that is the problem if filter is changed and indoor motor not running that will cause unit tice up causing leak, third the which is unl,ikely you have a leak. if i can help you anymore please let me know
Sep 15, 2009 | Heating & Cooling
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
1,183 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
