Question about Dometic Refrigerators
I own a dometic dometic refrigerator model RM 2310.3 installed in an RV. This weekend it soped cooling.When I checkthe rear heat is being produced in all modes, gas,elec and 12 volts. I'M not getting any coolingWhy
  • 787 Answers
Most likely you need to change the freon in the system. However, I don't recommend trying this yourself since it's dangerous. I recommend calling a technician to solve your problem.
Posted on Jul 07, 2010
  • 677 Answers
Have you checked if the refrigerator works on gas but not 120 volts or 120 volts. If so, the cooling unit is most likely OK, the problem is probably in the controls which will either require a new control or other factory repair. click here - if not continue
Is the refrigerator level? Yes - continue
Is anything blocking the refrigerators vents? if no - continue
Is there an ammonia smell coming from inside the refrigerator? If yes and cleaners or disinfectants haven't been used recently (they can smell like ammonia) then chances are that the cooling unit is leaking and will need replacing click here - if no continue
Is there is a yellowish powder or stain on or near the rear of the refrigerator cooling unit? If yes, chances are that the cooling unit is leaking and will need replacing click here - if no continue
If it does not cool on either gas or electricity but is getting hot at the rear of the unit chances are that the cooling unit will need factory repair or replacing - click here for why they fail or click here for info on factory repairs or parts - if no continue
Do you believe it is not working because it is not making any motor noise? Gas refrigerators do not have motors and can take up to 8 hours to cool. If the refrigerator does not work after running for some time click here - if no continue
Are the gasket rubbers around the door/s damaged or misaligned? Realign or replace? If no or you cannot repair yourself and refrigerator is still not working properly click here
  • ikechukwu joshua
    ikechukwu joshua Jul 07, 2010
    Troubleshooting a Defective Cooling Unit
    If you are having trouble with your Dometic or Norcold rv refrigerator then you are at the right website. We specialize in rebuilding the ammonia cooling units that power the rv refrigerator. The cooling unit is the set of metal coils that are attached to the back of your refrigerator. The three most common signs that indicate a bad cooling unit are:
    A strong ammonia smell inside the box, this would indicate a leak in the evaporator section. Look at our link rebuilding process for a more detailed understanding of how we repair a cooling unit with an evaporator leak. If the unit has leaked for an extended amount of time the ammonia smell may no longer be present but you will probably hear a gurgling sound coming from the back of your refrigerator a few minutes after you turn it on.
    If the controls are working and the cooling unit is heating up in the back but there is no cooling taking place inside the box this could be a sign of a blockage in the boiler section.
    Another thing to look for, if you unit is not cooling but you don't smell ammonia inside the box, look for a yellow powder around or just above the burner located at the back of the unit. This would indicate a leak in the boiler section. Since this leak is outside the box you would rarely smell it inside. I see these boiler leaks more frequently in the newer Norcold and Dometic cooling units.
    The three example above should help you identify your cooling unit problem. If you feel you have a different problem with your refrigerator or need further advice on troubleshooting your problem, call me at the above number or read below for a better explanation of what an ammonia absorption cooling unit requires to operate properly.
    What a Cooling Unit Needs to Operate Properly
    The cooling unit, or coils, of an ammonia absorption refrigerator is the heart of the refrigerator--it does the actual cooling. Everything else on the refrigerator either supports the cooling unit, or is an accessory. No matter how simple or complicated the controls of the refrigerator are, all cooling units require the same three things to operate:
    The unit has to be level
    The unit has to have adequate ventilation
    The unit has to have CORRECT heat
    A fourth issue is raised if the cooling unit has recently been changed. The cooling unit has to have been properly installed into the refrigerator.
    If the three above requirements are provided to the cooling unit, it should work and should work well. If it doesn't work well, then it is a bad cooling unit. It's really that simple. (Also, failure to meet the three requirements above when the refrigerator is in operation can cause permanent damage to the cooling unit.) Of course, don't overlook mitigating circumstances such as a main door that seals very poorly, which would cause a good cooling unit to look bad because of warm air continuously entering the box.
    Also, if the cooling unit seems to work poorly only during warm weather, it's possible that one of the requirements above is in a border line state. In other words, the venting, for example, may be adequate for mild weather, but not adequate for warm weather. A cooling unit could also be border line, but it would be prudent to look elsewhere first.
    Testing the Cooling Unit
    First of all, if the cooling unit cools properly on one heat source (i.e. gas or electric) and not the other, then the cooling unit, with only a few exceptions, is good and the problem lies in the heat source that is not functioning properly.
    Secondly, there are obvious signs of a bad cooling unit.
    If you smell ammonia in or around the refrigerator, and you haven't recently used ammonia for cleaning, the cooling unit is bad. No further testing is necessary.
    If sodium chromate is present on the outside of the cooling unit, the cooling unit is bad. Sodium chromate is a yellowish-greenish powder in solution inside the cooling unit. If sodium chromate is outside the cooling unit, the cooling unit has a hole in it.
    If you hear a relatively loud gurgling or percolating sound when the refrigerator is in operation (being heated), it is a sign of a bad cooling unit. The key words here are "relatively loud". A good cooling unit percolates when in operation, and if you get close enough and listen carefully enough, you can hear it percolate. However, if you hear noise a few feet away, it is a sign that the cooling unit has lost pressure and is bad.
    Testing the cooling unit is simply insuring that the three necessary requirements for the operation of a cooling unit (level, ventilation, correct heat) are met. Do whatever it takes to meet these requirements. If you suspect a venting problem, pull the refrigerator and set it on the floor. In fact, pulling the refrigerator and setting it on a level floor meets two of the requirements and leaves only one, correct heat, to worry about. Always test the refrigerator on the electric heat source, unless you are unable to because you have a gas only refrigerator. The reason for testing on the electric side is if the electric heat element gets hot, you can be better than 95% sure that you have correct heat, whereas even a poor gas flame will produce heat. To insure that the heat element is getting hot, you can touch the insulation pack (a rectangular or round sheet metal container filled with insulation located directly above the propane burner) to see if it is warm after about a half hour of operation. CAUTION: touch the pack lightly at first; it is possible under certain conditions for the pack to get super hot and burn you. If the insulation pack does not get warm, you have an electrical problem that needs to be corrected before continuing. If an electrical problem is not the electric heat element itself and/or you want to insure that some other electrical component (such as a thermostat) is not interrupting the heat element, you can hot wire the heat element for better testing conditions. The only weak link in this testing procedure is the less than 5% of the time that a working heat element is not producing the correct heat. See hot wiring for information on verifying the output of the heat element.
    After you have provided the cooling unit with its three requirements, allow plenty of time for the cooling unit to function. You should see signs of cooling in the freezer after about two hours. Allow six to eight hours, or even over night, for an empty refrigerator to come down to temperature. The ammonia absorption style of refrigeration is slower than the compressor style in terms of initially bringing the refrigerator down to temperature. However, once the desired temperature is reached, there should be no problem in maintaining that temperature.
    If you have done everything in this section up to this point and the cooling unit does not work or does not work well, the cooling unit is bad and will need to be rebuilt or replaced.
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
Fourwinds hurricane rv
We are Arcticold refrigeration, we manufacture brand new replacement cooling units for Dometic & Norcold RV fridges. Our cooling units all come standard with install instruction, installation hardware, and a lifetime warranty. Feel free to give us a call to free 1-888-782-6665 I can send you the install instructions by email if you would like to take a look at them. In most cases it takes approximately 2 hours to change the cooling unit. I will also need the model number of Refrigerator you have. Visit ArctiCold Refrigeration We keep it cold for some info. Below is a example of one model of cooling unit we build. It is a Dometic RM2852 shown in the picture. 39ede16a-9d21-4648-ad1c-33f0d0c45ff3.jpg 599bd524-a61c-4c24-afa2-1a1a9c84d92c.jpg
Mar 02, 2014 | Dometic Refrigerators
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
I have a Domatic RM 2852 in my RV. The freezer works fine but the refrigerator won't cool to 40 on electricity. It cools fine on gas.
You need to unplug the heating element from the circuit board and using a digital multi meter check the ohms. You should read approximately 44 ohms +/- 10%. If it is out of range change the heating element.
Aug 15, 2013 | Dometic RM2852 Refrigerator
Lhave a rm 2601 rv refrigerator and when I cut it on the freezer coil gets warm instead of cold.Also it is making a gurdling noise. when I open the door to refrigerator the it has a ammonia bad...
Shut it off and get it checked. Ammonia is dangerous as I am sure you are aware. Ammonia smell is an indication of a leaking cooling unit. Time for a new fridge. Sorry.
Oct 14, 2011 | Dometic Rooftop RV Air Conditioner
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
Refrigerators Logo
64 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
