Question about Sanyo DS19310 19" TV
No sound, no picture--apparently power not getting to the tv
When the set is plugged in to any outlet there is no picture or sound. It has died!!
  • 518 Answers
Do you mean ,,into the areal socket, then the co-ax connectoins are fautly is the fuse in the 3pin mains plug okay
Posted on Jul 07, 2010
Screen lights up but no picture just lines
see the instruction and fix it. God bless you
Instructions
    • 1
      Unplug the power cable if the TV is having issues turning on or off. To reset the electronics, it is important to not only unplug the power cable from the outlet, but also to unplug it from the TV. Wait a few minutes for the power to drain from the TV and then plug the cable back into the outlet and TV. A TV that is not working may not be getting enough power. Try plugging the TV into a different outlet or use a different power cable. Tweets, flashes, clicks and flashing pictures are all signs that the TV is not getting enough power.
    • 2
      Check that all cables are plugged into the proper positions and are secure. Normally if there is a problem with the picture, but not the sound, or vice versa, then a loose cable is the cause. If you have spare cables, replace the cable to check if it is the cable that is the problem and not another component of the TV.
    • 3
      Change the batteries if the remote is not working properly. Reset the remote by removing the batteries and then pressing the buttons and holding them down for 30 seconds. Then install new batteries. If you use rechargeable batteries, let them charge for at least 6 hours.
    • 4
      Adjust the brightness, contrast and color settings. Many times when the color is funny or suddenly becomes unrealistic, readjusting the picture settings is an easy way to bring the picture back to normal. Adjusting the focus is an easy way to deal with a lack of sharpness in the TV picture.
    • 5
      Check the orientation of the monitor if the picture is not straight. Any sources of a strong magnetic field can also alter the orientation of the picture. Some TVs may also have an external tilt control that can be adjusted. If the TV has been jarred or knocked about, then the internal or external tile knob may have been knocked out.
    • 6
      Run an internal diagnosis on the TV. This internal diagnosis is normally found within the TV menu. It can be called different names depending on the manufacturer. The TV will check all functions and hardware. If a problem is detected, then a specific code is displayed on the screen. Write down the code and call the manufacturer. The manufacturer will be able to decipher what the code means and let you know what is causing the problem.
Jul 20, 2013 | Vizio VF550M 55 in. LCD HDTV
SANYO Model CLT2054 Television
sounds a lot like you lost the video driver or control board functionality. From the 'decay' of your image, with sound still working, and all else being good, you're primed for a new video controller. Are you inclined to do the repair yourself? The service manuals are hard to get online, but the local service center MIGHT sell you one.
Feb 16, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
My Samsung is stuck in powering on and off problem. the set powers off and on about every 10 seconds. no picture or sound.
Take the tv aparts,check the tv whole power supply board,that the board where the power a/c cord plug into it.Check the whole tv power supply board carefully for dying capacitors parts.These capacitors parts are alway bulges up or puffing up on to it tops.U have all the tools also know basic electronic also soldering work too.Replaced all those dying capacitors parts are bulging up or puffing up onto it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2011 | Samsung LN46B530 LCD TV
Alba TV LCD4288DF 1080P Sound but no picture. On switching on get a very brief flash of the picture then screen goes blank, tried on all inputs with same results. It did sort its self out for a while but...
1. Check to see if the TV power outlet has power. Plug a lamp or something small into outlet to test for power. If there is no power in outlet, check your circuit breakers or power fuses.
2. Check to see if you have pressed the power button on the TV or on the remote controls. Check to ensure batteries are placed in remote correctly.
3. Check the setting of the picture brightness or contrast.
4. Check to ensure you have proper cable connections from your source going into your TV.
5. Check the volume settings on the TV.
6. Check to ensure the mute button is not pressed on.
Jan 20, 2011 | Televison & Video
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
No light, sound nor green button
maybe a lizard is die inside and shock your power supply circuit
Jul 01, 2009 | RCA 36F530T 36" TV
I loose my picture but i still get sound
Just try to reset so picture will come again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
This TV worked very will until the past two weeks when it refused to start up
Any sound? If so, it could be a bad display or high-voltage or associated problem.
No sound and no picture could be a bad line cord, power switch, blown fuse or AC problem.
In this case, make sure it is plugged into the ac outlet and the ac outlet is getting power by plugging in a lamp that is known to work into the outlet. If it does not light, then ther is no ac power at the outlet and you have a bad fuse or tripped circuit breaker (most likely) or (less likely) a faulty outlet or break in the house wiring.
Good luck! :)
Mar 08, 2008 | Sony KV-36XBR400 36" TV
TV won't turn on
32F530TCD4
I received this solution:
"This was apparently caused by using replacement flybacks. Add a .001uf cap (102k@2kv) from RL03 (the side away from the FBT) to ground. This will shift the picture a little then compensate a little with parameter 15."
In my case, i used an other flyback the HR8934 from Diemen to get a more stable picture without blooming, and add a 440pF (two 220pF capacitor in parallel) instead of .001uf to eliminate the tearing lines.bfde541.jpgac61dec.jpgdda8fac.jpg.
Dec 01, 2006 | RCA 32F530T 32" TV
Sanyo DS19310 19" TV Logo
125 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
