Question about Sony Playstation 3 (PS3) Console
Wont turn on just green light then red then goes orange around red
    Sergeant:
    Champion:
  • 297 Answers
Yes this is the red light and it is cuased by internal overheating if you use a good ps3 guide to fix it you will be able to play again or you can send it in for repair.
Posted on Jul 07, 2010
4 Suggested Answers
AshMan182
  • 40 Answers
SOURCE: Console wont boot up
Your xbox is dying. Is it still under warrenty?
Visit http://support.xbox.com/support/en/us/nxe/default.aspx
Posted on Jan 16, 2009
Big Hev
  • 64 Answers
SOURCE: ps3 wont start
This seems to be a very common & recurring problem. It is the "Yellow Light Of Death". For whatever reason, the game cannot read or recognize the hard drive. There are many reasons that you can get YLOD, but it boils down to one thing... you're PS3 is kaput. Here's something you can try that may help: With the solid red light showing, hold both the power button & disc eject button simultaneously! You'll get a single beep, then a double beep. When you hear the double beep, let go. You should get a 6 point menu on your TV. Try option number 3 first. As a last resort, try number 6. This opyion will erase all your saved info, but it is a shot at rescuing your console. If 6 works for you, you can access all your downloaded games & demos at the PlayStation Store. Trophies, too. Hope this helps. If you need a walk-through, message me here & I'll see if a can be of more help to you
Posted on May 12, 2009
Nissan G3
  • 5 Answers
SOURCE: Soon as turn PS3 on it goes orange then flashes red.
yeah, you have the yellow light of death, its an easy fix, check out some vids on youtube, i've repaired 2 of them so far, just make sure to use the flux and the heat sink, and you will be good to go.
Posted on Nov 09, 2009
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
Wont turn on as an orange button appears
I beleive this is a mainboard problem. If it is warrantied return or exchange. Good Luck
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Help me
Check and see if the light on the power supply turns green.
Green= Good
Red= Bad
Orange--->Green--->Orange = console issue.
any light on the ring of light?
Oct 05, 2008 | Microsoft Xbox 360 Console
X-box 360 wont turn on
Is your power box light orange or green. It should be orange if turned off and go green when turned on if it is red your power supply box is no good you can unplug it leave off for 10 minutes or so then try again if light doesn't go orange you won't be able to turn it on. I had the same problem and it was power supply box with red light got new one works great.
Jul 17, 2008 | Microsoft Xbox 360 Console
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Sony Playstation 3 (PS3) Console Logo
152 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
