Question about Daewoo DSA-122L Air Conditioner
Daewoo Nano silver a/c unit blows started blowing hot air only about one year after installation. Unit looks like the DSA 122L. Unit will not give off cold air no matter what button we push and no matter how long we leave it on. The longer we leave it on, the hotter the air gets, even in fan mode. Please help
3 Suggested Answers
  • 234 Answers
SOURCE: My mini split shows f8 and turns on/off alone
The unit is going off on a hi temp .Can you leave it off for a while and then it will start up if you turn it on?I would be checking the fan motor to see it will run alone when the unit stops.Also check and see how hot it is at that time.
Posted on Apr 07, 2009
  • 182 Answers
SOURCE: The remote for the DSA-122L
First make sure the batteries do not replacing inside the remotes.
Posted on Dec 19, 2010
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
Throws or sprays lots of water out the front on a daily basis which is soaking the carpet and furniture. The window unit is over ten years old and has been running non-stop for at least 5 years.
It sounds like that unit is getting a bit low on charge and is freezing up a bit....maybe even needs a good cleaning of the indoor coil... that would make it freeze also.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 02, 2010 | Daewoo DSA-122L Air Conditioner
FOR THE REMOTE CONTROLLER (P.N. 3108402300) I
if the remote is a slide which reveales the controls the battery compartment is under that cover
May 02, 2010 | Daewoo DSA-122L Air Conditioner
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
Daewoo split system model DSB-242lhg. Wont work on heat green light is on but no hot air
Is the unit in heating mode? If so, are the filters clean? Have the system repaired if you cannot fix the problem.
Mat
Jul 15, 2009 | Daewoo DSA-122L Air Conditioner
Apr 05, 2009 | Daewoo DWC-073C Air Conditioner
Replacement remote
You can find the nearest dealer here; http://www.e-daewoo.com/customer_service.asp Hope this helps :)
Apr 07, 2007 | Daewoo DSA-122L Air Conditioner
Daewoo DSA-122L Air Conditioner Logo
278 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
