Question about Garden
Full grass catcher bags fall off the bagger frame when on the 54" mower. The sides of the bags seem to fold up and let the bag fall off
  • 2,272 Answers
CAUTION: BEFORE ASSEMBLING GRASS CATCHER TO TRACTOR: • Depress clutch/brake pedal fully and set parking brake. • Place gearshift/motion control lever in "NEUTRAL" position. • Place attachment clutch in "DISENGAGED" position. • Turn ignition key "OFF" and remove key. • Make sure the blade and all moving parts have completely stopped. • Disconnect spark plug wire from plug and place where it cannot come in contact with plug. Care should be taken not to damage the parts and that the wheel spins freely at the beginning of each use. • If the grass catcher fails to pick up cut grass or leaves, it is an indication that clogging has occurred in the system or that the grass catcher containers are full. Usually this is indicated by the stopped movement of the full bagger indicator. a. Disengage blades, shift into neutral, en gage the parking brake and stop the engine. - Raise seat. Unlatch and raise cover. - Slide out containers and dispose of clip pings . - Replace containers, close cover, and latch. b. Unlatch chutes and check for clogging. - Remove all debris in chutes. - Reassemble and latch chutes c. Check to insure full bagger indicator has not become clogged. - The air passage hole must be clear of debris. Gently insert a small twig or wire into pas sageway to clear. Check the sides if they have got loose or cracked or may be not holding the bag as required then it may fall. Also check the frame if its bent or got bit loose then it needs to be re tightened and checked.In some cases it needs to be replaced. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 07, 2010
  • 787 Answers
What model is it?
  • oldgardeners Jul 07, 2010
    model # 917.249170
  • Tudor Valean
    Tudor Valean Jul 07, 2010
    No, I meant Manufacturer and Model Name.
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Attach bagger
ive got a JD 180 .with a bagger on it if you have the factory bagger
1st bolt bracket to back right hand side of tractor holes should allready be there next assemble bagger top to tractor bracket , hang collection bags (two) from top of bracket (open top to access) then assemble diverter tube all together three sections , snap end (wide) into bagger (no bolts needed) then fold back safety discharge cover on deck all the way snap the inlet adaptor into hole left by this (perfect fit) and last stretch rubber bungee up to deck wheel strut and place clip thru small moon clip there, now you willl need to replace your deck blades with the High Lift type (mulch) avail still from JD (theres a extra wing on back of it) this makes more air to scoot grass up the chute if not your gonna have a lot of cloggs
Oct 30, 2014 | John Deere Original 130 160 165 175 180...
Need to replace one bag on a 3-bag grass catcher. Where can I find one
dealer can order one any lawn mower dealer will order it take serial number off frame make of mower and order it
Aug 31, 2014 | Garden
I canot get a bagger kit for the 54inch cut lawn tractor in UK, can a 48, bagger be fitted and altered to fit which I can get in the UK
I have never seen a catcher for this size of deck, Husqvarna do not offer one, i am sure the deck aperture is different from the 48" machine, if the catcher is available in the US, would they just supply the upper and lower chutes? the 52" deck produces a vast amount of grass, so will fill the boxes very quickly, you would spend more time going back to the dumping area than actually mowing, mulching would be a much better option, if you have to collect would a tow sweeper not be better, it holds more grass, and you would not have issues with poor draught, and grass blocking in the chute ( a big problem with noise compliant machines, and damp grass , and side ejection )
Oct 10, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I need a grass box
WHAT IN THE H..... IS A "GRASS BOX" DO YOU MEAN A CATCHER BAG FOR CLIPPINGS????
#1 IT IS MUCH BETTER FOR YOUR LAWN TO LET THE CLIPPING FALL INTO THE GRASS, AS THEY DECOMPOSE...THEY FEED AND GIVE NUTRIENTS TO THE SOIL
Jul 30, 2012 | Garden
How to engage grass catcher on toro 22
Lift rear door, catcher bag has a hook on each side that must be hooked over bar on each end.
Jun 17, 2012 | Toro Garden
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mtd bagger not bagging ...its 100 deg today grass is short and the tube keeps clogging up w /grass it wont go into the bagger .how can i fix the problem??? chris
The MTD web site has a list of items to check:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=68&p_created=1027017166&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=214&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9YmFnZ2VyIGNsb2dz&p_li=&p_topview=1
Aug 10, 2009 | Gaiam Reel Lawn Mower Grass Catcher
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
