Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
HAVE OLDER RANCHER 44 NO SPARK AT PLUG ATTACHED SPARK TESTOR STILL NOTHING NEW PLUG CONTINNUITY FROM SWITCH TO COIL BUT NO WAY OF CHECKING COIL OR BEYOND HARD STARTING BEFORE THEN JUST QUITE WHILE I WAS CUTTING
    Brigadier General:
  • 4,088 Answers
Remove the flywheel cover to expose the flywheel and the ignition module. Remove the ignition switch wire from the module and retry for spark. If still nothing, try using a thin business card for a gap gauge between the flywheel magnets and the module poles. Insert the card, then loosen the module screws--and allow it to stick to the magnets. Re-tighten the screws and rotate the flywheel to remove the card. Try again for spark. If still nothing, then replace the module. Install the new part as above. Don't forget the switch wire connection. Good luck!
Posted on Jul 07, 2010
Miss fire spark #4
First, check to see if all spark plug wires are firmly attached. If they are, then look at or replace your spark plugs. If you have a testor, see if all spark plug wires are working well.
May 12, 2015 | Mazda MPV Cars & Trucks
I have an 11.5 hp Briggs It will start 2-3 times and then nothing NO spark. plug is new, I suspect the coil, what do you think?
use 2 thicknesses of a match book,or .012,,pull the black wire off the coil and start it,if it runs then a safety switch is bad
Apr 10, 2015 | Swisher 44-Inch 12.5 HP Trailcutter...
No spark on Huskvarna Rancher 55
disconnect any and all kill wires going to the coil... if you still have no spark then it can ONLY be the coil... if this produces spark then you have a kill system problem or your flywheel has no magnetism... and this can be the only solution as you do not have points/condenser or things just went full derp
Aug 27, 2014 | Garden
No spark with Huskvarna Rancher 55. New coil
anon re connect the kill switch. If this fail try connecting the two ends of the wire to the kill switch together.
Huskvarna Rancher 55 (~2000) no spark
could be in your switch. the ground wire needs to be attatched for new coil to work
Aug 26, 2014 | Garden
I have no spark on my honda rancher 350, how do I fix it?
Check... points, coil, magneto, switch, kill switch, neutral safety switch.
Aug 10, 2014 | Big Gun Evo Utility S/o Honda Rancher 350...
What would cause a no spark situation on my honda rancher 350?
Check...
Battery
Points
Coil
Magneto
Ignition switch
Kill switch
Neutral safety switch
Aug 10, 2014 | FMF ATV HONDA RANCHER 350 2000-2006...
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 rancher i have spark (dont know if good spark) and gas new spark plug and air filter and it wont start.
Check to see if your ignition switch ( on& off) switch still have both wires attached. Common problem with that saw, loose or disconnected wire
Aug 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
163 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
