Question about Cameras
The lens of my camera wont move back in when i switch it off or back out for when i switch it back on. It then appears on the screen system error (zoom) or sometimes it shows system error (focus)
  • Anonymous Mar 30, 2014
    Camera keeps on coming up with 'system error focus' when I switch it on.
I had a similar problem and is turned out to be a battery that wasn't charging properly, the camera just didn't have the juice to move the lens.
Posted on Jul 07, 2010
I cant use my camera it appers system error how can i fix this?
Please check if the lens can move free. If there is any obstruction, it will stop and the camera will give an error. Also never try to stop the lens from moving.
Start over again. Remove the battery, charge it. Place the battery and the memory card when you are sure the memory card is not in the locked position. Then close the battery door carefully, so the door is locked correct. Then switch on again.
If the error comes back, perhaps the lens is blocked inside (broken gear or something like that) you have to contact the service centre.
Jan 10, 2014 | Sanyo Xacti VPC-S770 Digital Camera
I have error code e106 on my 733 hp camera,whatis that?
CausesThese errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • something is blocking the lens
  • the firmware version is old
  • the camera has been abused
  • foreign material is inside the lensor
  • the lens is loose or completely off the track
SolutionFollow all of the steps listed below.
  1. Perform a power reset on the camera.
    1. Turn off the camera and remove any optional memory card.
    2. Hold the ON/OFF switch in the ON position until the HP logo displays and then disappears.
    3. The camera is now reset. When the camera is turned back on it should prompt for the date and time.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera.Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    1. Before turning the camera on, press and hold the Flash button.
    2. While the Flash button is depressed, turn on the camera. A Service Screen displays.
    3. Located at the bottom of the screen is an entry, F/W.
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately.
Nov 21, 2011 | HP Cameras
Nikon coolpix S3000 - lens error! - appears after turning on camera, lens goes out then in, message on screen will not go away, camera will not do anything at all except turn off. Does this mean the...
I got a same problem with different mode.
I planed to send it back to manufacturer, before packing it, I just knocked the back of camera with my palm in switch ON mode... the lens just retracted into normal position...
It can work for you to......
I am not an expert, it is just my experience I am sharing here.
If Lens struck with Lens Error!! on the screen, charge the batteries, switch on the camera, when the lens tries to move, feel free to knock a bit hard at the back of the camera with ur palm...... you cant hurt it any more than it already is., it might help the misplaced gears to aline back in if it is a minor problem.
Sorry about this un expert advice but it worked for me...
Just try it before sending in...
Feb 26, 2011 | Nikon Coolpix S3000 Digital Camera
Eror e6100 flashing
error is generic hardware error. normally some part of the infrared or display has malfunctioned.
Feb 02, 2009 | Sony Cyber-Shot DSC-P71 Digital Camera
Hp 735 camera error e106 then it turns off
When the camera is turned on, the lens is stuck either in or out and the camera gives the error E104 , E105 , or E106 . The camera then turns itself off. Causes These errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • foreign material is inside the lens or
Solution Follow all of the steps listed below.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera. Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately. See the HP document Recommended Firmware Updates for Photosmart 733 and 735 Digital Cameras .
Jun 23, 2008 | Cameras
Fawabi
0013 indicates that your camera has a hardware (related to Lens) defect.When dirt gets into the lens mechanism the lens wont retract properly.. You wont believe what i have suggested for a similar problem and it worked! Its a similar lens stuck error..
http://www.fixya.com/support/t240817-camera_error_e45
Mar 21, 2008 | Nikon Coolpix 3200 Digital Camera
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Cameras Logo
621 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
