Question about Microwave Ovens
I have a small area in side my microwave that shows gray metal where the paint came off/s this dangerous?
  • Microwave Ovens Master
  • 9,086 Answers
It can lead to rust, which can eventually lead to leakage, so it should be fixed.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
MICROWAVE TAKES LONGER TO COOK EVEN ON HIGH AND OCCASIONALLY SPARKS FOR NO REASON
inside your micro... walls are made of metal but protected with paint, if this paint is gone and the metal shows thats what happend you have to repaint the unprotected areas again, and the reason your micro... is not working so good anymore is due to the magnetron
Jan 31, 2014 | Sharp R-930AK Convection/Microwave Oven
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
My oven sparks from the metal plate on the side.
Check to see if there is any rust or cracks in the coating that came from the factory. Some microwaves use metal underneath an epoxy type coating and if it is exposed, it can cause an arc from the microwave generator. If there are any defects in the surface, it can be sanded down and you can purchase a can of interior microwave paint and put a coat of paint over the defective area. Also look for any exposed metal in the area of the sparks, there should no metal exsposed anywhere, if it is, cover it with the paint. hope this helps.
Feb 13, 2011 | GE Profile Spacemaker Over-the-Range...
Inside my Daewoo KOR-6Q27 microwave oven, underneath rotating glass plate, white layer (or paint) have piled off and rust have started to emerge. Can this problem be fixed or i have to buy a new one? Was...
I have painted many Microwave oven cavities. You have to sand down the pealed off rusted areas and completely clean and degrease. Before painting, I use laquer thinner as a cleaner degreaser. Fumes can be a bit strong but it has worked well of me. I normally buy an automotive spray paint. They have a lot of different colors and a lot of the import colors can really come close to the color inside the microwave. Spray on thin layers till you get good coverage and make sure you let it dry thoroughly before trying to use. The paint in a Microwave isi not a special microwave energy protective paint. it is only there to make it look pretty and protect the metal. So a good automotive paint normally works fine.
Sep 25, 2017 | Daewoo Microwave Ovens
I am from Macedonia and I would like to ask you a question about Daewoo Microwave Oven I have. During the exploitation, the white color under the plate, started to exfoliate in a circle, around the...
no its not a health hazard,but if you don't like the looks,they do make a cavity paint especially for microwave ovens,in either a small brush or spray applicator form
Sep 22, 2010 | Daewoo Microwave Ovens
Was cleaning inside of microwave and noticed the paint was bubbled and when I cleaned this area, all paint came off and metal was exposed 9about a 2 inch area). Should I use the microwave or will arching...
Hi Bonnie,
Do not use the microwave with the exposed metal surface.
What you can do is pick up some appliance touch up paint, it comes in a small plastic bottle with a brush. It looks similar to fingernail polish. It should be available at an appliance store such as Sears, Lowes, Home Depot etc.
Clean the area good and use sandpaper or steel wool if needed to make sure the area is smooth and clean. Then use the touch up paint to recoat the surface. Let dry before using the microwave oven, usually a couple hours or so.
May 01, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Mar 25, 2009 | Sharp R-820B Convection/Microwave Oven
Metal turntable's enamel chipped, so sparks fly.
Try Going To Your Local Hardware Store And Finding Enamel Repair.
It May Just Cook But I Hope It Doesn't.
Jan 05, 2009 | Sharp R-820B Convection/Microwave Oven
Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
Nov 15, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Peeling paint
The only real danger is if it continues, it can deteriorate the metal, allowing sparking and possible leakage.
It's a good idea to clean, sand, clean again and repaint the area.
High temperature appliance paint is available form stores like Lowe's and Wal-Mart.
Feb 17, 2008 | Hotpoint RVM1635 Microwave Oven
Microwave Ovens Logo
163 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
