Fan not working on my CPLE36-1C AC unit outside. Why?
Hello there, I have two Goodman AC units for my home. The one that is not working is a CPLE36-1C. When I turn up the AC for that unit, I noticed the fan on the unit outside does not work. I could feel that the fan motor is getting warm/hot, but the fan does not spin. What could be the problem? Would I need to replace the fan motor? Or could it be something else? thank you. tim t
  • 455 Answers
Hello Tim First Turn the power off! Try to turn the fan blade with a twig or something.Is it tight ? It should turn freely.If yes open the cover where the wires connect & check if the capisitor is expanded or leaking if so replace that with the SAME one (uf value&volts).Check for burnt wires also.The capicitor is a round or oval shaped can (looks like a large battery) with wires cliped/pluged in on top.Next let the motor cool off 1 hour and restore power.Does it BUZZ for a short time then stop?If yes its new motor time.Good luck
Posted on Jul 07, 2010
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
Hello, We bought a Perry Home in Georgetown TX last March and it is still under its two year warranty. Our air conditioner stopped cooling today. It has been working well for over 1 year. We came home...
You have a 10 year warranty on your AC. Call a Goodman rep and have it serviced. It will probably be a bad compressor capacitor. Bad wire or no refrigerant.
Jun 26, 2009 | Goodman Heating & Cooling
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Heating & Cooling Logo
372 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
