Question about Philips 42FD9932 42 in. Plasma Television
42FD9932/01S Hello everyone, I see lots of you guys are expert with this plasma so maybe I could get a help for my problem. I've got the plasma philips 42FD9932/01s which has suddenly decided not to work anymore. If i try to switch it on i can see just a quick screen coming and then it would just shut off and start red led blinking. I've opened it. Seems like one fan doesn't turn quickly as the others, sometimes I have to help it to start. If I help it to start it seems like the time before the unit shuts off is slightly bigger but anyway it shuts off after 1 / 2 secs max. I see the voltage on all the fans is 5V although they are 12v fans. Any suggestion? Is it normal? Thank anyone for any kind of help. Fred
  • 1 more comment
  • marbleit Apr 19, 2008
    Thank you Jerryg50,
    I have download a service manual yesterday. Even though it's not exactly this model of TV I see it's pretty similar. As you say and as the manual reports, the fault can be anything. Different outputs can interrupt the source and bring the microprocessor to "fault status". I might say I've got two failures here: one is the fan which is not turning (i see the difference when i help it to start) and then another one. I would try to locate the problem if I had the right schematics. I'll try to find something into the net. I'll let you know. The fan voltage , btw, is 5v on purpose.
    Thank you very much for the help.
    Fred
    Hello again,
    does anyone know where I could get the service manual, please?
    Philips 42FD9932/01s
    many thx
    greetings
  • uhu1 Jun 07, 2008
    hi
    half of tv screen went black few times, then full picture is destorted. can change channels and have conrtol of other functtions. is it worth getting repaired? 3 years old
    Genius:
  • Philips Master
  • 1,673 Answers
This can be the power supply, or one of the boards is pulling too much current and thus over-loading the power supply. There are many types of faults that can do this type of failure.
The service rep would use the process of making some tests as per the service manual, and then if necessary use the process of board swaping to find the failed board.
Jerry G.
Posted on Apr 18, 2008
  • Jerry Greenberg
    Jerry Greenberg Apr 19, 2008
    I am sure that if the set is still supported, the service proper manual can be purchased from Philips. There will be a charge for it. In the past, I have bought service manuals from them when I was doing TV service. I have paid in the area of about $40 to $150 for a service manual depending on the make and model. You will need Philips as your parts source once you found the fault. The exception will be if the part you need is generic and can be bought from a general electronics parts supplier. Even then you have to be careful, because there are many parts that are what we call "select on test" and must meet very tight specificatons.
    As for the fault, the best you can do is check the power drive device that runs the fan that is not turning. If it is an IC, then it will not be easy to test. You can check to see if there is proper drive voltage or drive pulses, depening on the design, and see if they are present at the device that is driving the fan. You can also see if there are supply volts to the drive IC. If the fan kick-starts and stops, then the fault is probably somewhere else and the part of the supply is being shut down for another reason. To see drive pulses and rapid changing control voltages a scope is essential.
    I would also say to check the power supply outputs, but the problem is that when the uPC sees a fault, it will shut down parts of the power supply to protect the system as best possible. This is where board substitution comes in to know the board that the fault is on.
    As for servicing, component level on the boards is not strongly supported. In the service shop they will only change obvious parts such as a standard capacitor or semiconductor.
    When changing any part, the cause of the failure is very important to locate. If it is not determined, there is a strong possibility that the same failure will occure again!
    I found with many of the Plasma and LCD display manufactures they not always not show component level on all of the boards in their service manuals. When I was servicing these sets, we were mainly changing boards.
    These boards are very complex and use SMD technology. The time and diagnostics involved to actualy troubleshoot these boards at the component level would never be feasible in a service shop, and especialy for consumer products. Also, the cost for the proper surface soldering equipment and diagnostics equipment for a service shop would not be feasible for consumer service, unless they were servicing high end industrial circuit boards and the return was worth the investment.
    Jerry G.
Hi!
I have the same problem.
I tried to connetct my computer to the plasma...with some luck...if you add second flat screen it could work. I did for me don´t ask me why.
John
Posted on Jul 10, 2008
Our Admiral AAV7000AWW washing machine makes a rattling noise during the spin cycle. We've had it apart and nothing appears to be loose. Do you have any ideas what might be causing this?
Hello, lisa
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Nov 01, 2011 | Admiral AAV7000A
My washer Whirlpool cabrio stoped the load and appear F1 code many times. I've read the manual and the problem is not solved.
Hello, lesia
Thanks Mike
Oct 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool duet dryer is making squeaking noise. I've tried some synthetic lubricant on the 2 drum wheels and the strap wheel and it last about 1 week and the squeaky noise reappears...
Hello, michel
Thanks Mike
Oct 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
Printer HP Colour Laser Jet 2600n Hello, Our printer is smudging a lot recently, I?ve scanned a document so you can see what I mean! We?ve cleaned the runner and changed all the cartridges, but it?s still...
if you have more that a year with you printer, maybe the mirrors and lenses of laser scanner are dirty, try to disasembly and clean it, 90% ara that the problem.
Aug 18, 2009 | Office Equipment & Supplies
2 inch black line down the middle of the screen
This is fairly common. If you don't perform a fix soon, you'll end up with burn lines. Follow this link. Pay particular attention to the soldering part, not the dismantling. A lot of plasmas from the last few years used a LG board made in Korea. The TV in question in this forum is a Hyundai, which is, yep you guessed it, KOREAN. So the pictures of the ribbons are accurate. Don't let someone try to sell you a fix. This site is supposed to be everyone helping everyone else out. SHAME ON YOU DAVE FOR SELLING HERE!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed-2.html
Nov 16, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vista to xp
What did the laptop have on it first? XP OR VISTA
What brand laptop?
Feb 13, 2008 | HP Pavilion zd8000 Notebook
Matsui 42" plasma TV
hi everyone, well i,ve solved our problem. i had the same head bashing problem for months,tried everything.what you have to do is turn all display settings to 0 and then run tv for several hours like that,then slowly bring up brightness and colour only leave contrast at 0. i,ve tested this for a week now and bingo the light show is over at last,my god the relief.good luck everyone
Sep 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips 42FD9932 42 in. Plasma Television Logo
474 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
