Question about Proform 380 CS Treadmill !
Slow only one speed
I have a pro form 380i, I purchase i from the Post Exchange Army, problem slow starting and will only run on one speed.
What could be the problem. and where is the best place to get parts??
AL
    Top Expert:
  • Proform Master
  • 12,223 Answers
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
Very slow hp8730w
try to do a ram test and an hdd test
Jan 19, 2013 | HEWLETT-PACKARD HP EliteBook 8730w Rugged...
I have a acer laptop that I let my son use and I've noticed that it is very slow and also it gets very hot. What do you think the problem is?
Dear Kristen,
1. Your laptop is running slow because there are too many applications running in the background. Go through the start menu and remove them if you don't need them.
2. Defragment your hard disks. Use a tool such as O & O Defrag Pro.
3. Your Acer heating up is a normal issue. Some older acer laptops heat up quite a lot. This is not an issue in laptops purchased after 1/1/2010.
If you are worried, get your laptop checked and serviced by a qualified technician or just simply hand it over to the nearest service center.
Oct 19, 2012 | Acer Computers & Internet
Video slow
You probably need more memory.
If you place a dvd in your drive and play it does it play slow and stall? If so you need more memory. If not then the site you are streaming the video from might be slow or have heavy traffic.
Your internet service provider might have you on a slow line speed. AT&T has different line speeds for their customers. If you purchase the lowest priced package then your line speed will be very slow on downloading and streaming.
May 06, 2012 | HP Pavilion ZE5730 Notebook
Computer running slow
Your RAM should be sufficient but there may be spyware or malware using it without your knowledge. Download (the free one)and run malwarebytes form here to check your system
http://www.malwarebytes.org/mbam.php
May 04, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
I HAVE A PRO FORM 995SEL. WHEN THE SPEED GETS TO
good about what might slow down some diode or varistor in the card and this failing, and if you switch the engine will do the same. and the problem that the lights are low voltage problem is suing the most Amperage treadmill, you should not connect the treadmill in a protective rail extension or voltage because the latter usually comes with a 15AMP capacity and whether the treadmill consumes more than that there is the problem. looking for an electrician and he will tell you the best you can do about the voltage. whether the board should not have to search a electronics technician and test the diodes, and thus the trasnformador covered here.
Feb 19, 2010 | Exercise & Fitness
My motherboard soundcard causing the computer freeze
the data exchange rate is too slow...either the mother board bus speed is too slow or you have insufficient RAM memory
Aug 15, 2009 | MSI COMPUTER K9A2VM-FD Motherboard
SLOW
hi..
u can improve ur computer speed by using a ram of higher speed. by purchasing a 4gb ram will kep up ur computer speed very high....
rate me
Jun 16, 2009 | Acer Aspire One AOA110-1588 Notebook
Poulan chainsaw 46cc 20" chain
You normally have 3 screws - idle speed - slow running and fast running.
First take care as if it runs faster than idle speed that chain will be whipping around also.
Second you have to determine what is the problem. Is it faulty at low speeds or high speeds ? or won't it idle.
If it has turn stops fitted to the screws you only have a small adjustments either way.
If it won't idle, try turning in the idle screw a half turn - until the chain just starts to move slowly.
If its dying at slow speeds, get is going and slow turn the slow screw out until it starts to run a bit rough then turn it back in to the point where its running smoothly.
Bad fast speed can be caused by simple things such as a blocked muffler ( insects too - I had one blocked off by a mudnest wasp) - otherwise get it running at full and adjust the fast screw as per the slow one - out till its rough then back in slowly until its smooth.
Suggest before all this tho that you get it running with the cover off the carby and then give it a good squirt of carby cleaner first - it may just clear out any 'poop' thats there.
(Have faith even tho I have a Poulan with a carb that refuses to run on anything but carby cleaner. I have pulled it apart a few times and renewed all the perishable bits buts its a real pig)
Feb 28, 2009 | Poulan Pro Chain Saw 46cc 20"
Slow and lousy connection
DON'T BE AFFRAID I WILL SOLVED YOUR PROBLEMS NOW . READ THIS AND SOLVE YOUR PROBLEMS . IF YOU DO NOT KNOW HOW TO USE THIS FORM OF TECHNOLOGIY , GO AND SEE A TECHNITIAN WHO KNOW HOW TO USE THIS TECHNOLOGY AND IF YOU ARE NOT SATISFY, COME AND WRITE TO ME IN THIS ADDRESS : angoundjou@yahoo.fr
Dec 23, 2008 | EnGenius EOC-3220 (EOC3220)
Proform 380 CS Treadmill ! Logo
73 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
