Question about Karcher 2500 PSI Pressure Washer
Where can i find pricing an parts for a pressure washer model 01903? honda 5.0 horse motor,2450psi/2.5gpm??
Gcv160 gjara
What is the make and model of the motor
May 20, 2013 | Honda Pressure Washer PSI 3000
How to replace piston rings on honda 6 horse motor
you need to remove the pump then the end cover from the engine remove the cylinder head the unbolt the connecting rod push out the piston hone cylinder and then wash the motor out with soap and water i use tide clothes soap and hot water put it back to gether now why does it smoke check the head gasket the over head engines blow head gaskets and **** oil from the crankcase
Aug 06, 2012 | Honda Garden
Honda 5HP pressure washer. When you press handle to get pressured water, motor does not rev up to give you high pressure.
Most small pressure washers do not have an automatic throttle control to increase engine speed on demand (activated by trigger on wand). You must set the governor/throttle to about max. to get the rated pressure. A honda motor produces 5 hp when it is turning about 3600 rpm. To increase the life of the pump, use about 80 % of capacity of the pump and increase only for stubborn debris.
Jun 17, 2011 | Honda Garden
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Which hot and cold pressure washer?
Something with a Honda GX motor
May 08, 2009 | Garden
Keeps stalling out
It sounds like you will have to adjust the governor system to hold the throttle on the motor open more so it doesn't bog the motor down. There should be an adjustment screw at the carb to perform this.
Hope this helps
Apr 06, 2009 | Air Tools & Compressors
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
Mar 10, 2009 | Honda Garden
Karcher 2500 PSI Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
