Scroll wheel with mouse (usb) immediately reverts to previous position in document
  • commander01 Apr 28, 2008
    Didn't work. It is an interface problem with Dragonnaturally Speaking 9.0
    President:
  • 2,712 Answers
Try to reinstall the mouse software/driver and see. This usually helps..
Let me know how it goes..
Posted on Apr 18, 2008
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    Just checking to see if your issue has been resolved… If
    you find that the solution/answer I provided led you to, or resulted in a fix,
    please close the ticket with a FixYa! Rating under my solution.
    I
    would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Yes, I guess Dragonnaturally Speaking 9.0 does not support the scroll function innately.
    Does it work in other documents? Say IE or Word, etc?
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
How do I make my scroll wheel work again? It just quit working. Now, I have to click the wheel and move the mouse up or down and it scrolls the page on its own. Nothing happens if I roll the wheel.
If you turn it over you should see 3 or 4 screws in a recess. Sometimes they are covered with stickers. Take the mouse apart and you will see the wheel mechanism and sensors. Clean all the inside with a soft brush.
Or
You could just throw it away and buy a nice new shiny optical wireless mouse.
Did you reboot the computer?
Nov 20, 2015 | Belkin Mini Wireless Optical Mouse...
Scroll is locked in the down position
If the Mouse USB receiver is connected to the computer via a USB Hub, disconnect the receiver and plug it in the computer directly. Hubs interfere with mouse wheel signals.
Feb 16, 2014 | Computers & Internet
Microsoft wireless mouse 1000 fix scroll wheel
I had a scroll wheel problem with my Microsoft Wireless Mouse 1000 and fixed it as follows.
With the corner of a sharp Stanley knife blade, I carefully peeled off the large pad at the back of the base of the mouse and removed the two screws that are hidden under it. Next I removed the screw located under the batteries. This allowed the top and bottom of the mouse to be separated. I cleaned out the inside with a small paintbrush and then sprayed a small amount of isoproplyl alcohol into the sensor at the right of the wheel. Now it's as good as new.
Aug 27, 2012 | Microsoft Wireless Optical Mouse USB...
My Fujitsu Lifebook is stuck in some sort of
Disconnect keyboard.
See if it's going to stop scrolling.
May 26, 2010 | Fujitsu LifeBook N3520 Notebook
Mouse keeps scrolling through pages
This sometimes happens to optical mice when they are used on a reflective surface. Do this:
1. Make sure there are no dust inside the mouse sensor
2. Use a proper non-reflective mousepad
If the above does not work, then there may be a hardware fault with the mouse. You may need to have it fixed or replaced.
NOTE: Please rate our help to keep this free service online
Jan 11, 2010 | Microsoft Wheel Mouse Optical PS/2 USB...
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
Microsoft Wireless Laser Mouse 6000 v2.0 Scrolling has gone awry
This may not be a solution for you but at least it may explain the cause of the problem. I recently had the same problem - the scroll wheel suddenly began to go crazy, jumping all the way to the bottom or the top of a document, or randomly skipping around. The unit was still under warranty, and Microsoft sent me a new mouse. Since they did not require me to return the old mouse, I decided to take it apart to see if I could find the problem. I found poorly soldered electrical joints to the optical sensor & LED which convert the scroll wheel movement to electrical signals. After I resoldered these connections the mouse worked fine again.
Feb 03, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft Wireless Optical USB/PS2 x08-72982 - I just want the wheel to let me scroll up/down. It's very sensitive and pressing it gives me that free-scrolling icon which I don't want. How do I disable...
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 06, 2009 | Microsoft Wireless Optical USB/PS2 Mouse...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
