Make sure that you have switched the Wii to component video in the system setting menus. Once you have done that, you should have a color picture in 480p! Hope this helps!
Allot depends on your DVD player and WII. Since the TV is a color one unless the movie your watching on the DVD player is B/W it will play in color, same with the WII. If your DVD player supports HDMI then select one of the HDMI ports on the TV (there are 3) same for the WII depending on what outputs it supports select one of the corresponding inputs on your TV. The user manual shows several options for various components and should be of some assistance in your connections.
I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used?
If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
[email protected]
Are you using the default video cable (Red, White, Yellow) for video and sound? Make sure the Red and White are connected to the audio in for video 2 and that the yellow is connected to the video in for video 2. It might also be labeled composite video on your TV. If you are using the Red/Green/Blue plugs labeled component or Y/Pb/Pr then that might your problem with the black and white video.
As for the controller sync problem, you should press the red button next to the SD card slot on the Wii and the red button under the battery door of the new Wii remote in order to sync the two.
What component(s) are you connected to this TV?And what type of A/V cables are you using? Does it only happen when you watch cable or directv or dishnetwork? solutiondoct
