Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 i have a problem with my lexmark printer, when i go to feed paper into it it will go to grab the paper but not grab it propperly, and never drags it into print, i will try to upload a vid onto youtube, i have tried resetting it and that has not worked, any ideas?
  • Anonymous Apr 24, 2008
    printer will not take paper to print it makes a grabing sound, but will not print faxes or print copys.
    I have tried all tips to resolve the problem but no results.
  • boypolar Apr 24, 2008
    The problem is ----- The copy paper wil not go through the rollers for copies or faxs, I have tried all sugested remedies but to no avail has this worked.
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
927
Posted on Mar 03, 2009
I done it! I found the solution (Lexmark X5470 ONLY) What you do is take off the paper guide and then look down, you will see 2 rollers, if the paper veers to the right, the fiddle about with the left roller and then put the guide back on, it should work.
Posted on May 17, 2008
  • danspy May 17, 2008
    Actually It broke again, it might work for you guys though, guess i'm never going to buy a lexmark again, this is the second time this has happened on a lexmark
    Genius:
  • 2,035 Answers
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Apr 26, 2008
Rint,copy,scan or fax on my x5470 lexmark all in one. I unplug and restart compture and the fax still says paper jam check rollars dont see noughting.
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Dec 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
I don't see a paper jam, but that is the error i keep getting. it will let me print or copy anything. the printer i have is a lexmark x5470
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Apr 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper feeds over 50% into printer, makes noises an stops. When I try to see the paper by lifting the lid, it's not there. It's as if its feeding into another area of the printer
One of the leading causes of paper jams is some sort of debris falling into the feeder. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects. If you're willing and capable, carefully lift your printer upside down. Any debris should just freely roll out from the feeder.
Apr 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper will not feed into printer, even with hand pushing on paper. rollers do not grab the paper.
The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Feb 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper feeds grabs to many sheets or won't grab any
this is not something you can fix at this type of printer. it's the mechanism that isn't designed well. the only solution is with a little help from you
Oct 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper feed jamming problem
had this problem also try looking for a tiny piece of torn paper in the feed wheel and remove the snag
Aug 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
290 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
