Question about HP Pavilion F1703 17" LCD Monitor
Power light flashing but monitor slow to come on. It takes 5-15 minutes, but then seems to work fine.
  • 11,361 Answers
This model has known problem with poor/contaminated solder joints at the four inductors, look at the leads. Also look for caps with bulging top.
http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Posted on Jul 09, 2010
Monitor is slow coming on then when on website clicking out of second tab flashes black
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
P2770h monitor flickers. progressed into the monitor shutting down after a few minutes. the monitor power on light flashes in a slow dim.
Is this happening while your are playing games or you are doing a specific task? If not try to change your connectivity cable (HDMI or DVI)
Aug 28, 2013 | Samsung P2770H SyncMaster Widescreen LCD...
Driver for Synaps mw9bbk
The flashing power light and very slow display is an indication that the internal power supply board is failing. This is usually caused by bad filter capacitors on the board. You should be able to repair the unit by replacing the bad capacitors.
Sep 25, 2012 | Computers & Internet
Syncmaster 920N 5 Minutes of dark Screen It takes 5 minutes for screen to light after computer has been awaken from "sleep" mode or if monitor has turned off while listening to music online.
Hello Dfrank,
The 920N units use the same power supply board that the 710T uses and it was a known issue with bad capacitors that fail. When they fail it can cause the issues that you are having - Either slow to show a picture, wavy display or no power and flashing power light. The boards can be repaired if you can do a little soldering, the parts are cheap. We have a step by step repair guide posted on our tech support web site at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-syncmaster-710t/ This is an easy repair for a very nice monitor, well worth repairing it.
I hope this helps, if so please rate my solution.
BuddyMc
Jul 28, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Engine light flashes
it is the catalist that is obstructed,the stone is broken inside,by temp it fails to let enough air through,
or replace,or open,break out one part for better air stream and weld closed again,
Feb 13, 2009 | 2002 Volkswagen Passat
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
383 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
