Have a Westinghouse LTV-32w3HD TV. Purchased reconditioned (you get what you pay for!!!) Works great on SDTV. When resolution is changed to 720p; bars on each side greatly reduce the picture. Auto adjust feature only for PC Mode.
  • surewinder Apr 18, 2008
    I have cable with a Motorola Receiver. I have/had tried the actions you indicated. Negative results. I use a good HDMI Cable and HDMI as the imput; however I am not sure what the receiver is sending (16:9 or 4:3). (I do have HD service)
  • surewinder Apr 19, 2008
    I have used the scaling button but it does not achieve the full screen that I want even by selecting fill.
    Master:
  • 788 Answers
What type of TV signal do you use? Satelite, Cable, Over-The-Air? Is you signal source HD?
If your signal is SD then it will not be widescreen, the bars on each side are present as it is fitting the image on your screen to the proper ratio (4:3). If you input signal is widescreen (16:9) then it would fill the screen. It's similar to when a widesreen movie is display in letterbox (black bars on top and bottom) on a standard TV (4:3).
You should be able to stretch a 4:3 input signal to fill your screen. I personally don't like this as it makes all the actors look short and wide. Circles on the screen become ovals.
You can also only take advantage of widescreen input signals when using the component (YPbPr), VGA, DVI, or HDMI inputs.
Posted on Apr 18, 2008
  • 2 more comments
  • Dean Joly
    Dean Joly Apr 18, 2008
    Use the "Scaling" button on your remote to switch from scale to fill mode. It's the button beneath the input button between the Vol and Ch buttons. It has a icon of a TV with a dual arrow in it. See page 12 of your manual here: http://www.westinghousedigital.com/pdf/1...
    Or use the menu button on the remote or TV and go to the display sub-menu. Select the "Aspect Ratio" item and pick fill to stretch your picture or scale to display it with the proper ratio (and show the black bars).
    This is not a problem with your TV but a feature, it all depends on how you like to view your content.
  • Dean Joly
    See page 18 of your manual.
  • Dean Joly
    See the top item on page 34 of your manual.
  • Dean Joly
    Dean Joly Apr 21, 2008
    What HD provider do you use and what type/brand/model of receiver do you have? Have you gone through the menu of the receiver and looked for an aspect ratio setting in it?
  • 2,334 Answers
It appears that you need to select the picture size to full or HD.
  • Jaime Hernandez Apr 18, 2008
    Press the scaling button that is located between Volume and channel buttons to select the "standard or fill" screen.
Tv has sound but picture only stays on for a few seconds
Since this is not CRT TV, error codes above is not applied to this LCD TV.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Check to see if you have 24vdc at the inverter board fuse as shown in the picture, the problem can be the inverter board or power supply board.
PARTS: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
May 12, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Apr 29, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
After about 2 or 3 hrs my Westinghouse 32'' LTV-32w6 screen starts to turn into line like the picture is all grainy how do i fix this problem?
Does it look like this? http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You may have LCD controller board overheating problem (the pictures show the board with shield removed)
Try cooling it with small fan blowing at the vents.
Mar 28, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV32W6HD. Turned it on and video is
If the picture goes bad after about 15~30 minutes, then more likely to be bad LCD controller bd. See sample of the failed LTV-32W3HD here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W6HD&limit=200
You can try running the TV with the back open with a small fan blowing in the back to keep it cool just to verify that it is heat related.
Jan 05, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
I have a Westinghouse LTV-32w1 Televeision. My screen is cracked and I would like to replace it, as the TV works great. Where can I buy the screen?
You will pay more for the replacement panel then you will for repalcing the TV. The part number is LTV32W1-LCDP and is no longer avilable.
Sep 10, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
