Question about Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive
I am having a problem with my drive asking to reformat.
I am having a problem with my drive. This has never happened to me before. I have a lot of information on my drive that I would like not to loose. My external drive is asking me to reformat. This happened after it was unplugged after it was safely removed from my wifes computer. At the time this occured, she was running XP Pro and I was running Windows 7. Is there a way to save my data without a reformat? Any help is greatly appreciated.
WhIzAtIt
  • 136 Answers
SOURCE: Maxtor One Touch
The harddrive itself has gone bad, only solution would be to replace the HDD inside the enclosure :-( sorry.
Posted on Sep 15, 2007
worldvet
  • 859 Answers
SOURCE: Computer does not recognize Maxtor OneTouch
Sounds like you need to remove the cable, uninstall the software, Restart, and then shut down. Now, from a cold power off power on. I know this seems tedious, but it has to do with the Last Known Good Recovery File and what is in Device Manger.
Now reinstall the software and if the software should call for you to "now" connect the USB cable, do so only when prompted or when the installer is done. Re: the latter, attach the cable. Windows ill say it discovered new hardware, point windows to your CD drive where the installer disk is located and allow Windows to locate the software.
Shut down and restart and your drive should be recognized now when you have a desktop. If not, post this back using the comment box below.
When replying to mine or anyone else's reply please address us in your reply, such as Worldvet: that doesn't make sense, please explain. And so on and so forth. This allow US to track what you've tried and from whom you were provided the solution.
Thank you for you indulgence on this. And, please be aware that, we all here want to see you fixed up and on your way. We all have a pretty good track record. However, there are times when a repair from a warranty service center is the only solution. However, I'm certain we all can get you taken care of and thanks for using Fix Ya.
Regards,
Worldvet
Posted on Aug 06, 2008
SOURCE: Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Posted on Jan 08, 2009
  • 13433 Answers
SOURCE: pc does not recognize slave drive
Look into the computer bios / setup and see if the drive is detected there.
to get into the bios or setup press the button indicated on the screen right when you turn the computer on, it can be either F1 F2, f10, del, space, esc depends. it should say on the screen.
Posted on May 21, 2009
  • 13 Answers
SOURCE: external maxtor isn't recognized on XP
Since you have important files on this drive, do not waste a lot of time with troubleshooting. If your drive is about to go out, you can put it over the edge that way and kill it.
Just to be sure, I would plug the drive into 1 other computer just to make sure. If you get the same thing, the problem is definently with the Hard Drive.
If this is the situation, I would take off the outer case to reveal the regular hard drive inside. You can hook this hard drive up to your computer as a slave and copy the files off. If your computer will not read the drive as a slave, and you have double checked the jumper settings and cable position.....you can try a program like "Get Data Back" to try and recover data off the bad/corrupted hard drive.
Posted on Jun 02, 2010
Im trying to view previously recorded videos on my camcorder but its asking me to reformat it
Yes, this happened to my miniDVD-R and -RW disks as well. No, don't reformat the disk !
I've been able to recover all (if not most) of the contents - video clips from those (bad/corrupted) miniDVD-RW ... and miniDVD-R disks ... (that I had recorded using the Samsung camcorder). I use the software tool - IsoBuster Pro . Inserted the mini-DVD into the DVD drive on my PC/laptop, and started the software . The process (to recover) may be very long .. i.e. it may take several to many hours for one miniDVD disk ... but it eventually enable me to retrieve the (lost) video clips.
Jan 24, 2013 | Samsung SC-DC173 DVD Camcorder
My Western Digital keeps asking to be formatted. I am unable to open the drive or reformat. What can I do?? I have a lot of files on this drive.
Hi, If you format the drive you will erase everything on it including your files. I would run your ant-virus you may have a virus on it. Second save all your files on a back-up disc. Then format the drive if you can. good luck.
Mar 20, 2011 | Western Digital My Book Premium ES...
I need to reset my HP6910P T9300 laptop psw without a reset disc?
If you can read the license sticker on the back and it's running vista you can put a "vista all versions" disc in and enter your number when it asks. I'd also advise you to reformat your hard drive from advanced options when it asks you where you want to install. if it's running XP you need the right disc for the version of XP your license is for. If you can't read the sticker, which happens a lot, download jellybean jeyfinder and run it. That will tell you what your license key is and what exact version of windows you're running.
Jan 14, 2011 | HP 6910P, Intel Core 2 Duo T9300 2.5GHz,...
Hi, I have a dell dimension 3000 and was given me a lot of problems so i inserted the windows xp cd and started a repair but as it was almost to finish i accidently tripped with the cable and turned it...
The message simply means that there is no other way that you can do but to run a reformat to your laptop since you have already ran out of memory. If you make a partition with you hard drive you have your important stuff saved on the other side of the hard drive. You will be asked to save them while performing the reformat process.
Nov 25, 2010 | Dell Computers & Internet
The hard drive crash I can get the recover up but it will not reformat the hard drive it has a lot of bad sector. have new hard drive have windows disk, try loading windows install driver for SATA drive,...
Try copying the driver files (install and otherwise) to a USB flash stick. Put it into a usb port, turn computer on. You should then be able to access the files throughout the installation.
Jun 29, 2010 | Gateway MX6912 Notebook
Why is my Verbatim USB hard drive asking me again to format the hard drive, i have saved data on it already but it says it will delete all data if formating again Please help ?????????????
this happens when the partition table information get corrupted, use partion table recovery software, the data on the hard drive is safe
Sep 18, 2009 | Computers & Internet
Ps3 problem
I have looked around for you and the only solution that seems to work for a lot of people is to take the hard drive out, put it into another ps3 (friends etc..) and reformat it, then replace it into your system and it will ask you to reformat it again then all should be well. Other to that you can always buy a new hard drive and replace the old one.
I hope this helps
Dec 24, 2008 | Sony Playstation 3 40GB System Console
Follow-Up to Hard Drive Question. (Tony Budz)
I'm not sure what he's asking you to do, but if you have a drive that's infected with a virus you can slave it to functional drive that's not infected as long as the functional drive is protected with software. Then you simply plug it into the ide chain and make sure the little jumper settings next to the ribbon are set to slave and the good drive is set to master. This is what he means by ide 0 and 1
Aug 12, 2008 | Computers & Internet
Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive Logo
23 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
