Sony kv32ds60u engineers menu
Hi can you help ! my tv sony kv32ds60u i messed with engineers menu lost picture on tv ! is there anyway of resetting the tv to default settings ! please help thanks
  • Anonymous Dec 13, 2008
    I have a Sony plasma screen that works with a tuner. It has started turning itself off and on again, the control inside must need changing - who can do this for me ? I live in london SW1
    Genius:
  • Televison & ... Master
  • 1,689 Answers
If you did not save the damage that you did, or do any damage from over-adjustment, you can make a re-set to before the adjustments were made by simply unplugging the set from the AC mains for about 10 to 20 seconds. If the improper parameters were saved, or damage was done from over adjustment, then this procedure will not work for you.
Read on for more details:
There is no default actual default. Each set is individualy set up for its optimum performance. At the factory, during the manufacturing process they set the EPROM firmware parameters to a so-called reference value before they start the calibration. This is done during production on the burner that programs the EPROM.
If the paramters are too far off to have the set working, you will have to take the set for service at a factory service rep. The factory service shop will most likely have to change the complete circuit board that constains the uPC EPROM with a new one that has the reference factory set-up. They will then have to go through the complete set-up with calibration procedures using the factory recomended calibration standards instrumentation to match for best performance. To manualy do a full calibration on the test bench it can be about 2 hours of work.
Because the factory service setup was not meant for consumer use, it is possible to over adjust parameters to the point where you can lock the set out of operation, or actualy do damage by over-adjustment.
Jerry G.
Posted on Apr 19, 2008
I replaced the light bulb. now when I turn it on it has a reset timer mess. how do i reset
Hi my name is Eric,
I hope I can help you with your issue ,
On a sony
 Using the TV remote press menu, go to setup and scroll all the way to the bottom till you see replaced lamp. then select it and click through to the yes and your lamp timer is reset
On panasonic you hold down a few buttons at once.
If I have helped you with your issue please click accept.
Thanks
Eric
Sep 26, 2009 | Televison & Video
Sony kp57hw40 tv blurry image,
Yes, you have a bad convergence Ic--set uses two of them---have someone change both and adjust the set in the Tech menu--if you need more information or help email me etower.766@netzero.net---
Aug 09, 2009 | Sony KP-51WS500 51" Rear Projection...
My ps3 doesnt show any screen on my regular tv anymore !!!
You will need to change the display settings back to normal for a standard TV. Obviously a little tricky if it's already hooked up to the TV that won't display a picture! If you do a manual (or is it called total reset?) this should revert it back to standard TV settings. To perform the reset hold the power button down for 10 seconds (I think it's 10 anyway) or until you here a couple of beeps and it should reset the display settings to it's default.
Hope that helps? Sorry I cant be more exact on the reset details.
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
Cool site. hi, i have sonny wega 42 inch 610 issue with blue
Its blue LCD mounted in light engine (optical block) and requires replacement.
Before, the solution was complete light engine replacement but now Sony Service Center will replace blue LCD only to fix it to reduce your repair cost.
Jan 30, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Sont tv
someone has messed with the menu settings. goto the menu and reset it.
Hope it all helps!
Oct 05, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
How can I reset the channels
some of the universal remote won't match the exact function of tv , try to fine another code of sony.
Oct 01, 2008 | Sony KV-35S42 35" TV
Sony Camera reset to default setting?
I do have a DSCT100 which has the same menu for this model.
You could go to the HOME menu, look for the Settings icon that looks like a briefcase. Inside the settings go to Main Settings 1 and look for Initialize.
You could also reset it by removing battery for a few minutes.
Hope this helps...ü
May 28, 2008 | Sony Cybershot DSC-T200 Digital Camera
Sony KP-51hw40 picture messed up but sound ok
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence/geometry
nope, not master reset or miracle button I'm afraid. You are suppose to write down the settings that you mess with so that in a case like this, you can go back and reset everything where it was. You will now have to call out a tech that knows what they are doing. The servicemen's menu is exactly what it says it is. A SERVICEMANS MENU!
Oct 04, 2007 | Televison & Video
Televison & Video Logo
323 people viewed this question
Top Televison & Video Experts
