Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I have a Whirlpool Duet Washing machine that continues to display an F35 error code. No matter which cycle I select, the machine will begin the cycle normally, then display the "SUD" error, then displays the F35 error code. I have unplugged the machine hoping that the memory would reset, however this has not helped. Does anyone have any suggestions?
  • rthomure58 Jul 07, 2010
  • 5,081 Answers
He F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Posted on Jul 07, 2010
    Thanks for your help! I'll give it a try and let you know if the procedure works.
  • INDIRA KUMAR
    INDIRA KUMAR Jul 07, 2010
    Please donot forget to rate and accept my answer...
    President:
  • 1,382 Answers
F35 error indicates Analog Pressure Sensor Failure. If this failure is displayed, there is a malfunction in the steamer component detected by the Steamer Electronic Board.
Please check for the following to solve this issue
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Thank you !!
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Sport Model WFW8300SW0 basket won't
    The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
    Hope helps.
    Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
    My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
    Hello & Welcome to FixYa
    F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
    Kevin
    Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    In some cycles the word sud appears on the display. Then the cycle will stop and F35 appears on the display.
    one of our techs has already answered this on the f35 error code click here http://www.fixya.com/support/t400054-error_code if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
    p.s to repair this issue you would replace the analog pressure switch the switch's part number is W10156252
    Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    F35 code
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    To remove the error display, press Pause/Cancel twice.
    Take care
    Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet -Sud displays and washer stops
    I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
    http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
    I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
    Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I get F35 error code on my duet washer
    Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch.
    Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Error code f35 on my washer
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool front loader
    I've had this same problem and had a service man come in. The reason for the colde is an over-gunked up machine due to the directions for amount of soap to use on he bottles being incorrect.
    Run the washer empty several timres with just vinegar in place of the soap and then repeat with bleach. I've been told this will take care of the problem, but it may take many cycles before the codes will stop appearing.
    Also, from then on, only use 3 tablespoons, yes 3 tablespoons or 1 ounce of detergent per wash. The 1/4 cup that most he detergent bottles tell us to use is way too much.
    Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet wahsher
    PLACEHOLDER FOR ART
    NOTE: If the error remains on the display, then call for service.
    please do not forget to rate and comment about your experience with fixya today.
    Aug 18, 2008 | Whirlpool Washing Machines
    Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
    174 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
