Question about Kenmore 62602 Electric Dryer
E 1 error code comes on after a minute or so and dryer stops
    President:
  • 1,382 Answers
"E1" error code indicates an open thermistor. The thermistor is located on top of the blower housing. Get to it by removing the bottom quarter panel. The thermistor has gone faulty and you should for a immediate replacement to fix this problem.
Thank you !!
Posted on Jul 07, 2010
Duet model GEW9200L. What does code 08 indicate?
there is no such error code on this dryer, that is likely the time left on the display... If the dryer stopped at the 8 minute mark with no error, check the door switch because it can interrupt a cycle, but will result in no error... Did you try to start it again, what happened? Whirlpool Dryer Main Control Board WP8546219
Jan 15, 2016 | Whirlpool Dryers
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
How to troubleshoot f70 error-code maytag dryer
Go to YouTube and ask your question there; I'd bet that a video or two will come up, thanks!
Sep 08, 2014 | Maytag Dryers
How do i find out what the frigidaire gallery series dryer error messages are
Hello Friend, this is Z. I appreciate your post!
To get the error code your dryer may be experiencing, attempt the following:
Wake your dryer by pressing any button except for CANCEL.
Press and hold the "CANCEL" and "START PAUSE" buttons simultaneously for 6 seconds to show the error recorder code your dryer may have. The error code normally appears in the display as an E followed by two numbers.
If your dryer shoes, E00 it indicates no failure code was detected.
I ask that you please follow up with a comment on the post, at your convenience, to advise if you receive an error and if further troubleshooting is needed.
Thank you!
Jul 17, 2014 | Frigidaire Dryers
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Kenmore dryer model # 11067072600 I am getting a F40 error code after 3-4 minutes in any cycle and then the dryer stops. I have checked all connections & continuity. During the diagnostics test mode...
i would have to guess that its a problem with the control board. if it were the user interface it would most likely fail right away and not after a few minutes.
either one are expensive, but the board should cost about 120 bucks
Mar 13, 2010 | Dryers
Hi, I am getting an error E68 on my dryer
Hi have you tried putting less into the machine as this could be a simple over weight problem
Oct 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 62602 Electric Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
