Question about HP Compaq Evo Notebook N600c
Hey its me again
I tried what you said about unplugging it and holding down the power button for 1 minuet and then I went to turn it on and just like before it wouldn't turn on any other tips, thanks.
  • 3 more comments
  • rc8787 Apr 21, 2008
    the laptop will come on sometimes, but usually as it starts to power up, it shuts back down. If you take the battery out and have it plugged up to the outlet, it will keep trying over and over to power up on its on, but will not. Any ideas with that info added?
    Not sure where the hibernate button is. I do see one with fn on it which may be the function key u mentioned. When u say upper left side, do u mean on the side of the laptop or on the keyboard?
  • rc8787 Apr 22, 2008
    ok, now I know what u mean. I've tried that 2. When I hold the buttons down together the fan or something will run as it would at normal start up but nothing else will happen.
    I thought the round, blue button was the power button. If this is the hibernate button, it's the one I've been powering down with. It shuts the computer all the way down. Is that what it is suppose to do? I guess the slide switch on the top right is the power button. I bought it second hand and don't have a manual for it. It worked fine for a couple days. I think, maybe buying used electronics is a bad idea.
  • rc8787 Apr 23, 2008
    Thanks for the manual download. But still no luck. Is there another reset button somewhere?
    Guru:
  • 1,342 Answers
Try holding in the Hibernate button on the upper left side. If that doesn't work try holding it in while also holding down the Function key.
Posted on Apr 18, 2008
  • 1 more comment
  • Georgia B
    Georgia B Apr 21, 2008
    How far does it get before it shuts down? Does it make it past the bios screen and try to load windows?
  • Georgia B
    On the keyboard. It's a round button.
  • Georgia B
    Georgia B Apr 22, 2008
    You can download your service manual Here.
    There's a troubleshooting guide to help you and disassembly instructions.
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Orange light trying charge
I would try this:
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
Disc will not eject
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
Aug 22, 2010 | Nintendo Wii Console
The ink system not working
here. try to reset your printer. this will clear annoying error displayed on your printer
1. Remove all cables
2. Unplug the printer power.
3. Press and Hold down # and 6 on the keyboard.
4. Plug the power cord back in.
5. Then release the buttons....after successful boot operation, try to print.
If that did not work.. you can also try this.
1. Press/Hold down the HELP and OK button..then unplug printer..release the button
2 Press/Hold down the HELP and OK button again..then plug the printer back in. Just Press and hold down the button while you wait for the printer to turn on (it could take a minute)
3 Now release the buttons and power it back on.
4 Error message will be displayed “improper shut down”
5 Press OK to reset the printer
6. Press both HELP and OK button again to start the resetting procedure of the printer.
Now try printing again...
If you find this very helpful..please rate this solution and vote on this on the YES below....thanks..
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
"Improper Shutdown" - Printer keeps turning on and off.
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
8. Be patient to let printer run its tests.
Sep 12, 2009 | HP Photosmart C6100 All-In-One Printer
Every light is solid except the wireless and security buttons...how can i get the wireless back working?
Try the following:
    1. when the unit is powered on, hold down its reset button for 30 seconds
    2. while still holding down the reset button, unplug the router from power and hold for an additional 30 seconds
    3. still holding down the reset button, turn on power to the router again and hold for 30 more seconds
After this process (a total of 90 seconds) is complete, your router should be restored to its factory default state.
Aug 24, 2009 | Computers & Internet
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Game stuck in console
Try thees steps
Turn the Wii.html#" target=_blank itxtdid="7750962">Wii off and on again after about 20 seconds. Press the eject button again. 2
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. Hold down the eject button for 5 to 10 seconds. 4Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. 5Call Wii.html#" target=_blank itxtdid="7751052">Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds Good Luck
Jan 23, 2009 | Nintendo Wii Console
Its not working!
try resetting the video, by holding down the power button till you hear 2 beeps. if no luck call 1 800 345 SONY. Free tech support and free 1 year warranty with all Sony PS3's they will send you a box with pre paid postage to send it to them and fix.
Dec 20, 2008 | Sony Playstation 3 (PS3) Console
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
HP Compaq Evo Notebook N600c Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
