Question about Refrigerators
2008 Fridgedaire fridg compressor does not run. door light goes on TS checks OK
  • 787 Answers
The compressor is most probably broken. Either way, this is best done by a professional, you don't want to mess with compressors because you risk serious injuries. So, call a technician, this is for your own safety.
Posted on Jul 07, 2010
Compressor does not turn on. Fridge beeps once, with a relay click, then 5 seconds later a second click, then nothing after that. Fridge has been out of action for 3 days and has no ice buildup can be...
if the click is at or by the compressor // the problem is at the compressor . . i would replace the start relay and the over load. tis should control the problem and if the comprssor is good . it will start up and run properly . mmm hope this helps ,, feed back pls ..
Jul 09, 2011 | Refrigerators
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
My fridge is not cooling,it is a kenmore 596.58642890.we un pluged it for about 5 days with the doors open to try to defrost it,we checked the seals and they are ok,the compressor is running as well as the...
I have a little question about the defrost. Did you see frost build up on the rear panel of the freezer. Is there no hot line coming from com compressor to condenser coil or cold from evaporator? Waiting on your answer, Sea Breeze
Nov 22, 2009 | Refrigerators
Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
Oct 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Fridgedaire glrs237zcb3
about the only thing you can do here is take the back cover off the unit see if the cooling fan for the compressor is running if it is and there is an Indian on the compressor then the compressor should be replaced if the fan isn't running then clear the fan once its running then turn the unit off for 30 Min's and try again
Feb 11, 2008 | Frigidaire GLRS237ZA Side by Side...
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
