Question about Garmin GPSMAP 498 Fishfinder / Chartplotter GPS Receiver
My garmin gpsmap 498 will not show depth or tracking points
likha
  • 790 Answers
SOURCE: depth display
reset your factory settings!
Posted on Oct 03, 2007
reef runner
  • 7 Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
MarineTech1
  • 76 Answers
SOURCE: I have a garmin gpsmap 440s that will only read
Sounds like the transducer is installed at the wrong angle or in such a way that it is getting a lot of air from something on the hull. If it is a transom mount, check that it is angled correctly and not too close to the motor or aft of some kind of thru-hull fitting that will cause turbulence.
Posted on Aug 22, 2009
  • 638 Answers
SOURCE: would like to buy a garmin gpsmap 178/178c owners manual
Contact Garmin and they will sell you one.
Posted on Apr 15, 2010
SOURCE: GPSMAP 188 / 188C Fish Finder / GPS GPS Receiver: Depth # just keeps flashing and not changing...
My GPS map188c depth sounde shows depth intermediate? What is the problem
Posted on Jun 20, 2010
Garmin gpsmap 498 backlight
Did I understand this right, you do know how to replace the backlight, but you cannot locate it inside the unit ? Try to look here: http://goo.gl/6hCS
Jan 02, 2013 | Computers & Internet
My positioner arrow shows a question mark blinking in top and doesn"tshow my position, I all ready change the anntena and the problem persist
the blinking indicates a satelite not finding you. push the done button for that location and the Garmin should reset itself. don't start the garmin inside any garage.
kdog
Dec 29, 2010 | Garmin Gpsmap 498, External Antenna With...
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
I have a garmin gpsmap 440s that will only read sonar depths a no wake speed. When I increase speed much past this the depth number blinks but does not track or change until I slow back down to idle again....
Aug 18, 2009 | Garmin GPSMAP 440 Chartplotter GPS with...
How can I download a manual for a Garmin Gps 498
Here's the link to download the manual for free. If this solves your problem, please come back and rate our solution.
https://buy.garmin.com/shop/shop.do?pID=370
Jul 31, 2009 | Garmin Gpsmap 498, External Antenna With...
Garmin 498 - trouble finding satellites
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
Nov 07, 2008 | Garmin GPSMAP 498
Depth display
Oct 02, 2007 | Garmin GPSMAP 498
Garmin GPSMAP 498 Fishfinder / Chartplotter GPS Receiver Logo
73 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
