Question about Intex "" Metal Frame Pool Set (56998e) 56998e
Filter assembly Intex 15X48
I am having a problem with the filter assembly. I have no idea where to hook up the skimmer(the filter that hook to the side of the pool). I have never done this before and it came with NO instructions!!
  • 52 Answers
The lower hole is for suction and the higher hole is for return.
The Pool Tech
Posted on Jul 14, 2010
Connect Hayward AquaCritter to Intex EasySet pool?
install a adapter to skimmer or t to accept adapter
Jul 16, 2016 | Hayward Pool & Spa
70110 sand filter. how do I connect a vacuum hose?
hook up to your skimmer over the basket to catch leaves
Jun 24, 2015 | INTEX Sand Filter Pump
I have a 15x48 intex metal frame pool with a 637 pump that uses A cartridges. I have cleaned out the filter and the skimmer and after hooking everything back up and bleeding air out of the lines I plugged...
if the system is consistently blowing air into the pool in large quantity, you most likely have a suction side leak that is allowing the pump to **** in air and return it back to the pool. try shutting the system off and inspect the suction side for any water leaks, that should lead you to any air leaks on the suction side. try turning the pump on and off a few times to catch any water spurting out of the suction side. Also, make sure the skimmer is now enough to not create a vortex and **** in air as well. Hope this helps.
Aug 24, 2010 | Intex 1 "a" Filter Cartridge Pool Pump...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Pool vaccuum
are you filling the vacuum line with water before hooking it to the skimmer?
Jul 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Jun 16, 2009 | Intex 4000 GPH Filter Pump
Intex "" Metal Frame Pool Set (56998e) 56998e Logo
311 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
