Question about Kenmore 24032\24036 Top Load Washer
Not self balancing
Worked fine one day, the next it is shaking all over , full or empty
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on Jul 07, 2010
My air conditioner is not working on my 2005 Nissan quest se. what may be the problem? it was working fine yesterday. there is plenty of antifreeze
anti freeze has nothing to do with air conditioning
shaking at speed is , tires, wheel alignment, suspension parts or balance and again is not related to air conditioning
working one day and not the next suggest a leak in the ac system and now the low pressure switch is not allowing the compressor to work
So to cover your problems
take the car to an accredited auto ac specialist shop and have it checked for leaks and gas
then take it to an accredited suspension for a thorough check of the front end , then have a wheel alignment done
Oct 04, 2016 | 2005 Nissan Quest 3.5 SE
Sante fe shakes violently accelerating 65 to 75 no light on
Check the constant velocity ball joints. They are usually hidden under a rubber boot. They split, dirt gets in and the bearings were away. The play will cause vibration and is typical to do it on curves. You can stop in a car park and with the windows wound down and radio off, turn the tightest circle you can at low speed. Listen for a clunking noise. Then turn on the opposite lock.
Aug 18, 2017 | 2003 Hyundai Santa Fe
Stops after i take it off, I have to shake it to get it going again, problem is intermittent, I have no clue...
Your watch is self winding and will run down (if fully wound) for about 2 days.
This type of watch thrives on use and if not used will stop. To avoid having to re-wind by shaking, it should be worn every day.
(Some makers say that to full wind up their self winding watches, they need to be shaken (gently) aboiut 200 times).
Apr 15, 2011 | Rolex Daytona 116520 Wrist Watch
Filter bag is full of dirt
its a weight that is supposed to be there ,shake it and forget about it ,this vac is very low maintenence
Mar 11, 2010 | Beam Industries 2900 Serenity Plus Central...
Wii balance board wont switch on
i got the wii fit. we hook it up. and it's work. but the next day. it's dont work. i put new battery in it. the light turn on. then shut off by the self. so i dont know what to do? please help us.
Dec 29, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
At 40 mph the car starts to shake. It last to 5o
I have this same car with exactly the same problem. Begins shaking at 40mph and stops shaking as soon as you let off the gas, but then begins again as soon as you press on the gas and smooths out as you get over 50. And the shaking is not felt through the steering wheel. Solution: Replace the transmission mounts. There are two of them, one on each side mounted on the frame right next to the shock strut. There is also a front and rear engine mount, but I replaced the two as described and shaking is gone.
Jun 29, 2009 | 2000 Buick LeSabre
Out of balance spin
next time its empty open the door take the metal drum and test for any movement if you hear/feel a knocking the drum bairings need replaced, makes it spin if centre
Oct 04, 2008 | Hotpoint Washing Machines
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Shutter release problem
Try removing the lens and the battery and leaving it for 24 hours - this can happen when the gremlins get into the works !
Jul 24, 2017 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Kenmore 24032\24036 Top Load Washer Logo
337 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
