Question about Whirlpool Washing Machines
Whirpool/Estate Model TAWS700E. When in the spin mode there is a loud ratcheting sound that appears to be coming from the spindle. Sounds like gear teeth rubbing together.
    President:
  • 1,554 Answers
This is an issue with the agitate gear not totally disengaged from the splines of the agitate shaft during the spin cycle and produce the gear teeth grinding noise. The gearcase needs to be checked to verify this issue. When the drive motor rotates clockwise, the main drive gear in the gearcase rotates counterclockwise, putting the washer into the drain/spin mode. This time the shift actuator moves forward on the other side and push the agitate cam in the other direction. This causes the cam follower to push the agitate gear up and then lift it off the splines on the agitator shaft.
Posted on Jul 07, 2010
  • sdouthit Jul 07, 2010
    Would it be easier / cost efective to replace the gear box as oppsoed to fixing it?
  • Jahn27
    Jahn27 Jul 07, 2010
    I strongly recommend to replace the gear box as opposed to fixing since it would be easier and other parts inside the gear box will eventually wear and break. The gear box is part number 3360629 and costs about $180. But it's a choice yours to make.
Oven knob spins in circles no control
There should be a metal spring cip ring around the spindle of the knob which keeps it tight around the spindle on the switch. Sounds like its snapped. Compare it with one that works, they should just pull off and push back on, but with a little bit of resistance.
Nov 26, 2013 | Estate Kitchen Ranges
My Elite H3 washer has been making a loud knocking sound during spin cycle for awhile now. Recently the clothes have been coming out wet. Today the drum stopped all rotation. I took off the back and the...
it sounds like the spider gear is bad,this is usually from using to much detergent,you can check the shocks but it sounds like the gear is gone.you'll know when it's the gear,it's very loud in the spin cycle,unfortunitly the gear is around 4 to 5 hundred dollars and then there's the labor bill,most likely better off replacing the washer.check out this video and you'll hear the sound i'm talking about....... YouTube - Kenmore front load bearing 18 months and kaput!
Mar 21, 2011 | Kenmore Elite 45986 Front Load Washer
Sounds like gear or something is stuck in washer
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. To watch a free video on how to check and replace this part go to www.appliancehelponline.com/servicemanual.html this will walk you thru this. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations.
Mar 30, 2010 | Estate TAWX700JQ Top Load Washer
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Estate washer TAWS700E
Peace Friend,
ngafm At your service!
Things wear out! So is life!
Sounds like the coupling conecting the transmisiion to the agitater is worn out!
If I were there hands on I could be definite.
Only a hands on laundry tech can make thediagnoses.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE
Sep 03, 2008 | Estate TAWX700JQ Top Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Washing Machines Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
