Question about Frigidaire GLTF1670A Front Load Washer
The motor doesnt turn the washtub.
The load size hasnt changed. It appears to have lost power. Itll try to turn it but it wont spin.
    Champion:
  • 274 Answers
Remove the back and see if the belt is still in place,the drm is inclosed,unplug before removing back
Posted on Jul 08, 2010
Agitator and washtub don't turn
sounds like the drive belt remove the front panel and look under the wash tub for a broken belt
Dec 18, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My moms front loader is a frigidaire gallery series. when she tries to start a load itll bring in a lil water and then just stop. don't understand why it is doing that
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Jul 19, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Spin cycle doesnt work on any setting. Timer appears to be working. Spin cycle initiates and hums but doesnt spin
this could be one of two faults a program fault or a motor fault
first check the motor,,if its a brush type check lenth of brushes if worn out change them if the fault is still there its the program bord
Aug 26, 2010 | Amana NTW5400TQ Top Load Washer
Won't spin. The coupler is good and bypassed the lid switch. Mother-in-law heard loud rattling sound. Is tranny shot?
very possible,but a chance that the clutch,and or basket drive has worn out,becareful that the motor mount hasnt broken and the coupling hasnt lost connection to tranny,also,the couplings dont always "break"-sometimes they strip or round out
Mar 08, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer says LE and hasnt drained all the water
I have the same issue - Had this washer for 6 yrs - up to now - it's been great. But, now I'm not sure what that problem is. Looks like the bin only spins counterclockwise - not clockwise. I can hear the motor trying to spin - then eventually I get the LE error code.
Dec 06, 2009 | LG WM1812C Front Load Washer
I have a Kenmore Elite washer. It will not spin on it's own. If I turn the tub and close the lid I can get it to go through the spin cycle.
More than likely your clutch/brake for your washtub transmission is going out/is out. A way to check it in washing machines is to have it run up to full speed or near full speed, wet your hands, and then cup your hand around the very top of the rotating washtub with only your 4 fingers inside the washtub, thumb outside on the non rotating part of the washtub and slowly attempt to stop the tub from spinning by gripping it. Generally if your clutch/brake is going out you'll be able to significantly slow or even stop the washtub from spinning before your fingers get too warm from friction. Make absolutely sure your fingers at the very least are wet, this reduces friction to your fingers without which could burn your fingers.
Fixing the clutch is not for anyone but very mechanically inclined and professionals. If the clutch is bad, take it to a qualified repairman.
Oct 30, 2009 | Kenmore Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Kenmore 110.82984120 Washer fills and washes but wont spin at end
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753. mounts directly to the motor shaft and connects to the transmission, when you ge the part itll be apparrent
Mar 01, 2008 | Washing Machines
Frigidaire GLTF1670A Front Load Washer Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
