Question about Toshiba 36AF61 36" TV
Would it hurt a Toshiba TV to leave the power on all of the time? We want to turn the cable off, but leave the power on, resulting in a blank screen. Will that damage the tv?
How much power does my toshiba 35AF44 use??
Posted on Jul 21, 2010
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
What's wrong with my Toshiba LCD TV? I have sound but no picture. I've read forums and websites but they all have slightly different info. Please help
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 16, 2015 | Toshiba Televison & Video
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
HI, I have a 42 toshiba regza tv that is 3 years old when watching tv the screen goes blank and the sound is still there i power it off then back on and the picture is fine. Somtimes wont happen for days...
If you are using a hdmi cable take it off and switch to component cables if the problem goes away keep it that way. Sometimes the hdmi hookups have bugs like this.
May 25, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
The power light blinks 3 times. What does this mean?
Toshiba Flat Panel Television how-to instructions, help and tips Three times so far, just the tv not the cable. Toshiba Flat Panel .... Timer light blinking red. TV will not turn on by power button on TV or using the ...
tv.manualsonline.com/.../toshiba/.../flat_panel.../product_problem toshiba.justanswer.com
Mar 11, 2011 | Toshiba Televison & Video
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
The screen has narrow white lines across the top 3 inches, on cable and with a VCR Tape in.
hello,
Where all colors are involved - the lines are essentially white or gray (or with a slight tint due to slight unequal settings of the color adjustments), look for something common like an incorrectly adjusted screen (G2) or master brightness/background/bias control or a problem in one of these circuits, a defective power supply or a problem in the blanking circuitry:
Screen (G2) or master brightness/background/bias control - mark setting and then see if a slight adjustment removes the retrace lines. See the chapter: "TV Adjustments". Of course, if this happened suddenly, the problem is not due to a misadjusted control though a dirty pot is possible - turn it back and forth - this might clean it and restore normal operation.
Power supply or connection to CRT neck board - insufficient voltage will result in the CRT never totally blanking. Check (usually scan derived) power supply components (from flyback).
General power supply - check B+ for correct value and ripple. A main power supply fault might result in these symptoms (and usually many others).
Blanking circuit - this may be a part of the video/chroma chip or separate. Check waveforms to determine if the blanking pulses are making it to the video output.
May 28, 2010 | Toshiba MV13L2 13 in. TV/VCR Combo
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Toshiba DLP 46HM95 - blanking out issue
I am assuming that when the set blanks out, you don't notice the power light flashing any certain sequence. What I would try if that is the case, would be to press a button on the remote control to bring up a menu on screen when it blanks out. If you can bring up any writing on screen while the picture is blanked out you know the Lamp is doing its job. Also, do you lose audio when this happens? If so, it could be a problem in the power supply or if you have the cable connected directly into the TV's tuner stub, the problem might lie in the Tuner. If you have On Screen Display when this happens and audio, then it looks like there is a problem in the video circuits of the TV. If you have a cable box hooked into the TV, the problem could be there also. Now you know why the Toshiba Repair Center gets the big bucks to figure out these things.
Mar 12, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 36AF61 36" TV Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
