Question about Sony Audio Players & Recorders
Sa-wis100 sony subwoofer problem
My sa-wis100 sony subwoofer switches on but 'protector push power' comes up and nothing happens. apparently its the ventilation. Please help.
  • 8 Answers
SOURCE: Regarding Sony SA-WM250 Subwoofer
There is probably a bad solder joint or loose wire inside of the sub box. If you can, unplug the sub, take the screws out and remove the back to inspect the circuit board. A clean solder joint is pointed and shiny, with the solder evenly distributed in the hole. Also check to see if any plugs are loose. Plug in the audio input and then the power, but be very carefull not to touch anything inside the box while the cord is plugged in!! Play some bass at moderate volume so there is pretty constant sound. Now, take a screwdriver with an insulated handle and gently tap around on the connectors and circuit board. Tap a little harder if nothing happens, also tap in different areas to try to force the sound to cut out. You can try to locate where the bad connection may be by tapping lightly and zeroing in on the location. When and if you find the problem, you will need to solder the connection with a soldering iron. If you don't have a friend to help, try a local electronics store. Good luck!
Posted on Jul 13, 2007
early1234
  • 871 Answers
SOURCE: sony sa-wx90 subwoofer
thats called electrical recoil, the energy that is stored bursts out thru your subs therefore you hear your subwoofer bang.
i suggest you clean your wirings.
hope this helps.
Posted on Jan 14, 2008
SOURCE: SONY SA-WM500 SUBWOOFER
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Posted on Sep 25, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a Sony SA-WX700 Subwoofer and it powers up
Replace amplifier output big IC that seems defective and not giving sound to speaker.
Thanks.
Posted on Jun 13, 2010
  • 15 Answers
SOURCE: Sony SA-WMSP87 Active Sub -- No sound, but can still turn on/off
Replace R404.... Good luck !!!!
Posted on Feb 03, 2011
Sony KE-42TS2U. Nothing happens when the TV is
Seems some thing wrong with power input plug or may be with power board in side the tv. first confirm with different power socket.
Oct 07, 2013 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Power turns(light) but no sound. Fuses all good??
apparently there is are some components on the main board that need replacing:
This is usually what needs to be replaced on these subs.
Replace
R830
R831-4.7 ohm 5% 1/4w fusible
C860 - 082 mf 5% 50v
Direct from Sony:
hxxp://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
c860 is Part # 113616400 $2.14
r830 is Part # 121284900 $2.14
Jan 22, 2010 | Sony SA-WX700 Subwoofer
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
Sony SA WX 700 - Fuse (6.3 A 125V) keeps burning out
The switching power supply transistors have shorted out. Other parts may be gone also. A difficult fix. Too bad, it's a great sub.
Sep 13, 2009 | Sony SA-WX700 Subwoofer
No sound from Sony SA2500 subwoofer
Please intimate exact model number written on sticker pasted at back of Sony subwoofer to provide you help.
Aug 01, 2009 | Sony SA-WX700 Subwoofer
Sony SA-VA 100 won't turn on
You can try a factory reset.
Push and hold down Dolby NR, stop and disc 7 buttons, then push power.
Otherwise it looks like $60 to $100 repair bill. These are not the most repair freindly units.
Good Luck.
Mar 08, 2009 | Sony SA-VA100 System
No sound
Hi, I've had this problem with the M-VR400 and apparently I had the Tape2 Monitor button pushed on, and I was trying to listen to Video-1. Well, mentally I said I have nothing connected to Tape2 Monitor so I figured the machine couldn't decide on sound Input properly, so I turned off that button and my Surround Sound came back on just like Magic! :) Hope that helps.
Sep 23, 2007 | Mitsubishi M-VR700
618 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
