Question about KitchenAid Architect 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
MAKES ICE BUT THE MOTOR ON THE DOOR WON'T TURN SO NO ICE COMES OUT
woodchuck789
  • 4070 Answers
SOURCE: Ice is not turned by motor mechanism to dispense ice
The motor is behind the ice bin. Remove the ice bin and see if the motor will turn with out the load of the bin. If it will see if you can turn the augur in the bin by hand. It could be locked up by ice in the crusher or tunnel.
If the motor doesn't turn, test it to see if it gets voltage when you depress the switch. If it gets voltage and doesn't turn it's bad. It could also be two weak to turn a load.
Posted on Aug 15, 2009
  • 1218 Answers
SOURCE: ICE MAKER WILL NOT MAKE ICE
Good day,
The first thing to check is the freezer temperature. If it is allowed to go above 15 degrees the ice maker will lock out by design.
If the freezer is O.K. then follow these steps to isolate the problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jun 13, 2010
  • 257 Answers
SOURCE: ice maker works, but won't
Make sure the bucket is pushed back all the way so auger engages the motor. You may have to turn the auger by hand and push to line it up correctly.
Posted on May 10, 2011
imufo2
  • 3773 Answers
SOURCE: Ice maker making ice cubes but won't dispense
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 16, 2011
SOURCE: The ice maker makes ice
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Posted on Dec 01, 2011
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice won't come out of door, no motor noise
Make sure the holding bin is in its proper place. Some have a safety that will not let the dispensing motor to operate if the bin is not mounted properly.
Jan 21, 2013 | Refrigerators
Ice won't come out
if it's making ice, but the ice won't come out, it is likely going to be the dispenser motor (found behind the ice bucket).
the other possibility is the lever where you put the cup could not be hitting the switch, but most likely it is the dispenser motor.
May 21, 2012 | GE Mwf Ge Refrigerator Smart Water Filter...
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Every half hour or so it sounds like a power surge...an electrical sound coming from the upper section of my French Door bottom freezer refrigerator. I do not have the water hooked up for ice making...and...
You have a problem with the control board program. If the ice making button is turned off, the ice maker should stop working completely but it sounds like it's wanting to make ice.
Jun 28, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker works, but won't dispense from the door. Motor turning, but no ice coming out.
May 10, 2011 | Refrigerators
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice wont come out of the door dispenser. Ice mover motor wont ru
take the bucket out of the unit to make sure the bucket is not frozen stuck. then it it still does not turn the motor, i would guess the dispenser motor is locked up and needs replaced.
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
KitchenAid Architect 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
