Question about Carrier ZQA183RB Thru-Wall/Window Air Conditioner
Need a thermostat for the Carrier ZQA183RB window unit
    Guru:
  • 1,524 Answers
Call 1-800-673-1262 give make and model number.
Posted on Jul 07, 2010
How to check if the thermostat of my AC home carrier
A thermostat is merely a switch that cuts unit on and off if unit. is working then fine however a quick check is to bypass switch jumping the 2 wires if NothING happens it's your AC unit not thermostat this is a low voltage BUT ELECTRICITY KILLS so be caeeful
Aug 15, 2015 | Carrier Heating & Cooling
Dca213d window unit keeps freezing is it thermostat?
Check for badly bent fins or obstructed/dirt impacted fins on the outside of the unit. Could also be low on gas. Try setting the t/stat to various settings see if its turning off/on at higher settings, if it does most likelt stat is OK. Also make sure you drian is clear.
Aug 12, 2014 | Carrier Heating & Cooling
Carrier model FCBNF030 where is the filter located in the unit?
There may not be one. Most filter messages on a thermostat go by accumilated run time. They are just a reminder and the thermostat message has to be reset. If its there it would be at the unit inlet were the return plenum connects to the unit. They dont usually have both if you have filters in the return grills you dont need them at the unit.
Jan 13, 2014 | Carrier Heating & Cooling
Carrier thermostat blank lcd display
Like have a clogged drain and the float switch is tripped. Check the drain line near the indoor unit for a piece with two wires. Remove switch and check for water or look in emergency pan under unit for water. DO NOT LEAVE SWITCH OUT, must vacuum clog free or blow out with compressed air.
Aug 09, 2017 | Carrier Heating & Cooling
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
I replaced the power cord on a carrier ac window unit 24000 btu model yc-d , now the compressor will not shut off regardless the thermostat setting
You have probably one wire in the wrong place on the back of the switch. There should be a wiring diagram near the electrical compartment on the window unit. It will show you where the wire needs to be. You are probably just a terminal off.
May 01, 2011 | Heating & Cooling
The unit never turns off. It appears the thermostat is not working.
If it's logistic thermostat don't keep in maximum. Keep in 11th hr position.If remote control, check your room sensor in front of the coil, may be defective-Replace it.
Dec 20, 2010 | Carrier 52PQ307 Wall/Window Air...
I have a carrier heat pump model # 38RQ034300 I need instructions for. To maintenance and use thermostst correctly
That is model number for your outdoor unit. Thermostats are not dedicated to any particular model outdoor unit. You need instructions for the thermostat so the thermostat make and model number are needed.
Oct 16, 2010 | Carrier Heating & Cooling
Carrier thermostat reading stuck on 50 but doesn't work
If it is Carrier tstat. Some have resets other dont. Kill power to insid unit. WAit five minutes turn back on. If it has batteries take them out. But the storm may have damaged the tstat. I had a thunderstorm damage 11 tstats in one building. You can buy a tsta at Home depot that will work and they are easy to wire. Just make sure you get the coorect tstat. If the unit is straight cool electric thats the easy one. A heat pump you need a Tsta with two stage heat one stage cool. You can pick one up for about 25 to 30 dollars. Please call back for more help be glad to assist.Rusty
Jun 13, 2009 | Heating & Cooling
Carrier ZQA183RB Thru-Wall/Window Air Conditioner Logo
77 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
