Question about Fuji FinePix 3800 Digital Camera
Card not initialized? how do I initialise this?
    President:
  • 1,382 Answers
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Posted on Jul 07, 2010
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Apr 08, 2014 | 1996 BMW 540i
How to initialized this card with out losing my pictures.
Not sure what you mean here. Have you already initialised the card and lost photos or do you want to initialise it without losing pictures already on it?
If it's the first part you need to use some recovery software to get your pictures back.
If its the second - you can't. Initialising a card will wipe the photos - and then you are back at 1 and will have to use some recovery software.
The only way you can do it is to copy all the photos off the card first - then it doesn'r matter.
Alternatively - buy another card.
Mar 12, 2012 | FUJIFILM FinePix AV100 Digital Camera
How do you initialise a memory card without losing the photos
You can't. Initializing (formatting) your memory card will erase the card. But formatting the card with your camera is a necessary step to either rejuvenate the card, or minimize later file error problems that will crop up if you don't do such. Backup/download the photos that are on the card to your computer before initializing.
Jun 05, 2011 | Cameras
Camera says Card Not Initialised
Download any pics from the card using a card reader if necessary. Then, go into the menu and find "format" or "Initialize" and follow the on-screen instructions.
Oct 21, 2010 | Fuji FinePix Z1 Digital Camera
New compact flash card installed. Camera says card not initalizes . how do you initialise card?
Go into the menu and find "format"(might be called "initialize")...follow the on-screen instructions.
Sep 27, 2010 | Fuji FinePix S7000 Digital Camera
Card not initialised.
You need to download the pics to your computer using a card reader. Then, format the card in the camera to completely erase and initialize it.
Jul 23, 2010 | Fuji FinePix A900 Digital Camera
How to initialize totally erased memory card.
initialise(format)
  1. press < or > to sellcet ok
  2. pressing the MENU/OK button erases all the frames(files) and initialises the picture card
Oct 21, 2009 | Fuji FinePix E500 Digital Camera
Memory card not initialising
Same answer I just gave to someone else. The first thing to do is to try to copy any data that is already on the card before you put it back into the camera and initialize it! Otherwise you will lose every photo on the card!
Once you are sure that you have copies of the photos, or that there is nothing in there that you can recover, put it back into the camera, go into the camera's menu, and select format or initialize, and let it do its thing.
Another solution would be to put that card aside in case you can later recover the images from it, and buy a new card to use in the camera. This holiday season you can get a one or two gig card for nearly nothing!
Dec 15, 2008 | Fuji FinePix A500 Digital Camera
Fuji FinePix 3800 Digital Camera Logo
96 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
