Question about Elo Computers & Internet
I can not hear any sound through the speakers of my ELO 1527L touchscreen monitor. I have a stereo 3.5 mini jack connected from my PC sound card and then to the speaker input on the back of the 1527L. This same cable and sound card work fine on another monitor. The ELO documentation does not mention if the 1527L speakers are stereo or mono, so not sure if this is a simple cable problem or not? Any help appreciated
  • 274 Answers
The Elo ET1527L Monitor has stereo speakers. Within the OSD (On Screen Display) you can control several properties of the monitor like; brightness, contrast, positioning, color, and SOUND. See the buttons on the right side.
I recommend setting the sound to 100%. The speakers are small and weak. They are pointed to the rear, I assume for customers to hear.
The buttons do have a lock-out feature too. If they don't respond, while on, hold down the top two buttons and the screen should display Lock / Unlock. Wait until you see the one you want and then release. The power button lock out works the same way, holding top and 3rd button to lock/unlock.
The device drivers give you an option to use internal (monitor beeps) and external (PC port) sound sources.
Posted on Nov 21, 2017
SOURCE: pc4 elo lcd screen
Your BL Inverter is bad.
Posted on Apr 28, 2008
SOURCE: terratec phase 22 problems with getting stereo sound
You must make stereo cable (adapter), from 2 mono outputs to 1 stereo.
Posted on Sep 01, 2008
  • 9 Answers
SOURCE: BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Posted on Oct 19, 2008
I got one ....pirate_4200@yahoo
Posted on Jan 02, 2009
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    How do you hook up sound from surface rt to acer monitor 2014
    To connect anything to the speakers on your acer monitor you need to use an audio patch cable that has 1/8 inch or mini headphone jacks on each end. Like this one.
    5mm Male to Male Stereo Audio Cable...
    You connect one end to the headphone jack on your Surface RT and the other to the audio in jack on the monitor. Make sure the power is on for the monitor and that the volume on both is a third or half way up and you should be able to hear the sound.
    This is for the monitors user manual.
    Acer AL1715 User Manual Amazon com C2G Cables to Go 27413 3
    Jun 13, 2014 | Acer 22" X223w LCD Monitor
    No sound from speakers
    You don't mention the sound card(s) in the PC nor the method of connecting to the monitor. Some video cards have HDMI connections for audio and video out to a monitor and will not allow any other audio outputs to work. Regardless of sound source interface, check to be sure that the audio source is the one that is NOT part of your video card and is NOT set to output DIGITAL audio signals.
    Once this is done, select the the "add-on" or "expansion slot" sound card (if it is the type that plus into a slot on your motherboard) or the "built-in to the motherboard" type (if the jacks are soldered directly to the motherboard) as the DEFAULT or ENABLED. Set to ANALOG output - NOT digital if a choice is offered. Connect the speakers. This should be via cable terminated with a stereo mini jack - NOT a special digital optical or coaxial cable / connector. Most modern PCs will have several mini-stereo jacks from which to choose - nearly all use the GREEN ringed jack for the FRONT (or main) left & right stereo speakers. Regardless, if yours has GREEN jack, you should use it - if none have a color code, look for markings that indicate either "speakers" ,"output", "front" or "L & R". If there are no indications, check your manual. Set your volume level on the lower side, play an audio source and adjust speaker volume and / or audio mixer settings in the system tray as needed.
    Only one sound card will work in a PC. Make sure that all connections are made to the ENABLED card, otherwise no sounds will be heard. Digital output is primarily targeted to facilitate connections to external amplifier and speaker system - most often like those found in a Home Theater PC setting - or a monitor / TV connected by an HDMI cable.
    I hope this helps & good luck!
    Jun 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
    Cant figure out how to hook them up
    Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
    The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
    1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
    You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
    Jun 27, 2011 | Bose MediaMate Computer Speakers
    Have a hanns 194 d monitor. i can;t get the sound to work. Help!
    Are you connecting the audio cable from the PC audio line out jack (green) to monitor audion line jack (green) with stereo mini phone jacks? You should verify the the speakers in the monitor are working by feeding it with the sound from MP3 player to narrow down the problem.
    Apr 07, 2010 | Hannspree HC-194D 19" LCD Monitor
    Speakers don't Work on HP Pavilion f1903 desktop
    Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
    Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
    How do I get sound from the Acer LCD monitor?
    connect stereo audio cable from monitor to pc audio output
    Mar 27, 2010 | Acer 22" X223w LCD Monitor
    Cant get sound out of speakers in monitor
    How is it hooked up to the PC? You need to use mini stereo phone jack connect one end to the Green Audio input of the monitor and the other end is connected to the Green audio line out of the PC. Then you need to set the volume controls at the PC and at the monitor. You can also try using MP3 player as an aduio source to see if you get the sound OK, If you don't then the problem is in the amplifier inside the monitor, if you do, then the problem is in the PC sound card.
    Mar 23, 2010 | Sony SDM-HX93 19" LCD Monitor
    Monitor's audio out not working
    You need to connect a line out from your PC audio card (green mini stereo phone jack) to the monitor audio line in jack (green mini stereo phone jack)
    Feb 16, 2010 | Computers & Internet
    Need the sound drivers for the monitor
    You do not need sound driver for the monitor, but you do need the sound card driver for your sound card. Your monitor has powered speakers built-in, you just need to connect the green mini stereo jack from sound card audio out to monitor audio line in and adjust the volume control at both monitor and the PC.
    Nov 30, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
    Kenwood Receiver connected to my pc
    using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
    or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
    good luck.
    Nov 12, 2008 | Kenwood VR-406 Receiver
    Computers & Internet Logo
    133 people viewed this question
    Top Elo Computers & Internet Experts
    Ricky Ostrom
    Ricky Ostrom
    Sam DeGonia
    Level 1 Expert
    Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
