Question about Culligan Sediment Water Filter
How do I change the o ring at the top of my sediment filter, it's leaking water on the bypass switch
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
On the top of the head is pressure which is depressed to relieve the pressure off housing. Inside the head ( when you unscrew the bowl) is a screw, spring and small o-ring as part of the pressure relief button. First see if the screw is loose and tighten. If not you can take this apart, inspect and repair as needed.
RJ
Posted on May 21, 2011
What else can cause this leak
there is a plunger inside them takes o rings too
May 02, 2015 | Refrigerators
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
I have a Culligan Super-S filter and I think the meda needs to be changed. I'm getting a lot of red water stains. Can I repack this myself? If so, can I use another manufacturers media?
Yes you should be able to replace this yourself and yes you should be able to use filters from other manufactures. Just check rating on the filter for listing of applications. To change the filter there should be a bypass valve on water line to filter. You normally push a button that routes water around the filter. There should be a spanner wrench to grasp casing of filter housing to loosen it.There also should be a small button on top of the filter housing to push down to relieve pressure to make it easier to remove filter housing.
I would make sure that you can get the right filter before doing anything. If you have what you need than bypass or shut water supply off,remove filter housing ,install new filter.Clean o-ring seals and put light coating of petrolem jelly on o-rings. Reassemble and tighten snugly.Turn water back on and open bypass,check for leaks and tighten a little more if needed. Thank you.
Feb 04, 2011 | Culligan Sediment Water Filter
We also installed the water filter GXWH40L. We never had any issues and have gone through probably five replacement filters. We recently changed the filter and have horrible water pressure. We changed it...
Check the micron rating on the filter. A typical filter will be 30-50 micron. If the new filters are a finer micron 5-10 these will reduce the water pressure significantly and plug up much faster. Also note if you have more sediment occurring. If on a well, hook a hose up to the drain at the well tank and flush the tank out to a floor drain, take note of any sediment, let the well kick on several times to flush completely.
RJ
Jan 06, 2011 | General Electric GE SmartWater Household...
Filter canister stuck
This is a very common problem. There are many reasons for this.
1. The canister was tightened with a wrench when re-installling. NEVER tighten a filter housing with a wrench after replacing the filter! Only by HAND! This is the main reason they are so hard to remove.
2. Filters swell in the housing.
3. The housing itself can swell.
4. The pressure relief button does not work properly.
5. Sediment buildup causes back pressure.
6. Sediment gets trapped on the threads from previous filter changes.
7. Off brand filters, especially those made overseas, frequently are not sized according to specs and can cause these problems. It is best to stay with a brand you know and has worked previously.
8. A bad o-ring will cause people to over tighten the canister because of leaks. Inspect and lubricate the o-ring (every filter change) and replace it yearly.
The best way to remove a stubborn filter canister is to shut off the incoming water, bypass the water softener, go to the nearest cold water faucet and let it run until the pressure dies off. Turn off the outlet on filter, hold the pressure relief button down on the housing (to relieve any more pressure) and remove the housing with the "appropriate" filter housing wrench. If it is still hard to remove repeat the process. After removing the canister, clean the head and canister threads with a clean cloth, lubricate them with silicone lube or plumbers water supply lubricant. It also helps to clean the inside of the housing with a 1/2 tsp of bleach, rinse and wipe it out thoroughly. This prevents any introduction of bacteria into the water system, which is also a very common problem and where "smells" can derive from.
RJ
Nov 15, 2010 | Culligan Under Sink Water Filter
My sediment filter is leaking where the bottom screws into the top. Never had this problem before. I made sure there was not mineral buildup on the threads or where the surfaces come together. I would...
The o-ring is either pinched, rolled over, cut or missing and needs to be replaced. Take the housing off, check the o-ring, clean it thoroughly, turn it over, lubricate and re-install if it is ok. If not o-rings are available for pre-filter housings at any water treatment dealer and most hardware stores.
RJ
Sep 07, 2010 | Culligan Sediment Water Filter
Culligan-water control valve leaks
If this is a Culligan neutralizer you will need to call Culligan for replacement parts as they are proprietary. You can pick up the seals for the by-pass at Culligan and replace them yourself. Depending on the PH of the water and your water usage the calcite should be replenished on a yearly basis. So you may want to have them out to do that also.
RJ
May 16, 2010 | Culligan Sediment Water Filter
GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Feb 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Aug 21, 2008 | Frigidaire FRS26R4A Side by Side...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Culligan Sediment Water Filter Logo
308 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
