Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
Epson stylus photo rx685 the problem is, waste ink pad in the printer is saturated, I have removed all the wested ink in the priter, but is the same problem that am experiencing. Please help me solve this problem.
Go to www.octoinkjet.co.uk/wib/ to download one of their inkjet ink pad reset utilities. It may just solve your problem. I couldn't clean or replace the ink pads on my epson RX700, so I bought their special adaptor kit. It solved the problem for me. If you already have cleaned the ink pads, maybe you can just download the reset utility. I hope it works for you.
Posted on Jan 03, 2011
Replacing waste ink pads on epson rx685
Actually it will very hard for you to access the ink pads for it was designed to be only touched by their service center. I would pressume your printer is giving you errors on waste ink pads full? Try this to reset the counter and be able to use your printer again..
http://fix-your-printer.blogspot.com/2010/04/how-to-reset-epson-stylus-photo-rx690.html
Sep 25, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Waste ink pad is saturated
You need to reset your printer's waste ink pad counter. Go to this link to download the resetting program http://www.mediafire.com/?atkkzx0sfcxeke1
Good luck.
Feb 23, 2011 | Epson Stylus Photo R1800 InkJet Printer
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
Trouble codes - red and green light flashing alternately
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 820 service manual can be downloaded from here:
810/820 http://www.mediafire.com/?m6ouftizois
Jan 11, 2009 | Epson Stylus Photo 820 InkJet Printer
Epson stylus 830Uink pads full not printing help
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson stylus photo 820
Hi Ikarp9090
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (820), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Apr 29, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson C46 has stopped printing with message saying service needed but nobody wants to make it carry on working
If both printer lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
If you wish to pursue this matter further, report back.
Apr 12, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
1,095 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
