Question about Olympus FE-35 Digital Camera
I use rechargeable batteries in my FE-35 and they are constantly showing up as empty. They show as full for about 30 secs and then they are shown as completely empty. It's very frustrating. Has anyone else experienced this? Is there a solution?
  • Olympus Master
  • 3,287 Answers
This may not be so much an issue with the camera as much as a problem with the batteries. Since these are type "AA" battery packages, you should attempt to use them in another device - such as a small flashlight or other device that can operate on AA batteries.
If the batteries fail to to power the flashlight (or other test device) for more than 5 - 10 minutes after charging overnight (or as long as directed by the battery charger), the problem is with the batteries. It is very important that the batteries are charged properly. Properly means for for the required amount of time AND in the correct charger. There are different types of battery types: NiMh, NiCad, NiZN, Li-ion, etc. Using the wrong charger to charge the batteries could cause unpredictable results - or create a potentially dangerous condition. Additionally, some battery types develop a "memory" and can be responsible incomplete charging and rapid discharge. This happens if the initial charge is insufficient and the batteries are not completely discharged prior to recharging. It may be possible to recondition these batteries - but this size battery is relatively inexpensive, so replacement might be a better option.
If the batteries are working okay in the test device, then the problem may lie in the camera itself. Test the camera by installing fresh, AA alkaline batteries. If the camera rapidly discharges the alkaline batteries, it's a safe bet that the camera has a problem.
Please rate this reply if you found it helpful - good luck!
Posted on Jul 07, 2010
I have a problem in my dell laptop battery. I have charge alomost 1 hours and is show full battery and time backup is 1 hour and 30 min. then after 20 min. it shown 35 min. backup
The battery may be near the end of its usable life. As batteries age, they cannot store a charge as long as they used to. Also, if the battery is constantly being charged, this could cause the battery to lose its ability to keep a charge. The best option is to replace the battery.
Please rate my solution to let me know how I'm doing. Thank you!
May 13, 2011 | Computers & Internet
Recharged battery and camera will not turn on. Checked battery showing 4.3 v indicating full charge. what now
remove battery from camera
wait a few sec.
plug it in
pres RESET on camera (paper clip hole)
power on
Mar 02, 2011 | Canon PowerShot A3100 IS Digital Camera
Pictures are misty if we take them in the sunlight & the battery power becomes lower quickly even if it is charged full.
You should know that if take pictures against the sunlight it will be misty. About the batteries, if those are NiCad batteries, it has a problem called memory effect. If you recharge the batteries before it's completely empty, the next time the battery shows it needs recharge when it reaches that level. So recharge the batteries only when they are fully empty. You will have to replace the battery now.
Dec 23, 2009 | Vivitar ViviCam 5340s Digital Camera
Battery shows empty with new batteries. Recent development. Put batteries in, take a couple shots, battery is empty. Tried with several pairs of batteries. Contacts OK and tight. Suspect a software...
Take a look in your camera's menus. There should be a place where you can select rechargeable or non-rechargeable batteries. That setting enables or disables the battery charging circuit. If you are using rechargeable batteries, the camera must be set accordingly so that the battery charger will turn on. If you are using
Alkaline batteries such as Duracell or other types of non-rechargeable batteries the charger must be disabled. If you do not set that parameter correctly, you will get the symptoms you describe.
Oct 04, 2009 | Pentax Optio M20 Digital Camera
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
Wide angle mode switch stuck??
repair... olympus will charge about $60
Oct 02, 2008 | Olympus FE-100 Digital Camera
Shows empty battery even with new batteries
If they're AA, don't use "HEAVY DUTY". They don't have enough power. Use alkaline or rechargeable, and recharge at least 15 hours even if your charger show they're fully charged after a couple hours. Please leave feedback if this helps.
Jul 26, 2008 | Olympus FE-210 Digital Camera
Olympus FE-35 Digital Camera Logo
98 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
