Question about KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator
The ice maker stopped working on our Kitchenaid KBRA20EMSS fridge. What are the recommended steps to diagnose the problem?
    President:
  • 1,430 Answers
This link should get you started http://appliancehelponline.com/refericemaker.html
Posted on Jul 07, 2010
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker continualy runs even when ice tray is full
theres aproblem here, I dontquestion that your hearing something operating, but if the valve is being activated, its going to fill with water( thats what it does!) so if your not geting water every few minutes something else is"buzzing"i would look elsewhere fro your problem doesnt sound like the valve
Jan 10, 2009 | KitchenAid Architect KBRA20EMSS Bottom...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Not Making Ice BUT making a "trying" sound
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 18, 2008 | KitchenAid Architect KBRA20EMSS Bottom...
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator Logo
406 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
