Question about Invacare Pronto M51 Power Wheelchair
When i turn the power on the lights come on ( on top ) then a light comes on the bottom (the light looks like a wrench ) then all the lights go out and the chair won't move.
  • 2 more comments
  • Neil Wood Jul 09, 2010
    Hi. When the light that looks like a wrench comes on, does it flash? If it dies count the flashes between the pauses, the number of flashes is the fault code. Let us know what it is and I will be able to help you. Neil.
  • Shannon Foster
    Shannon Foster Oct 24, 2012
    five flashing tool light
  • Shannon Foster
    any help on chair with 5 flashing tool light?
  • Martha Bunch
    Martha Bunch Jan 01, 2014
    no I need help.... the chair will not move at all
Wrench flashes 9 times
Posted on Oct 08, 2010
DISPOSAL DOES NOT WORK.
There is something caught in bottom of it!to clear it you need a Allen wrench on the bottom of disposal.
Jan 25, 2015 | Electrical Supplies
What do these icons mean 2996 gmc envoy
Do you mean 2006 GMC Envoy?
Top left- car with squiggly tire tracks and a wrench- that means something is wrong with your Stabilitrak (traction control) system. Top right- triangle around the car with squiggly tire tracks- this light comes on when the light on the top left comes on. It also means something is wrong with the Stabilitrak system. Bottom left- Antilock Brake System warning light- This means there is a fault in the antilock brake system. Considering that the stabilitrak control is part of the antilock brake system, it looks like there may be a common problem affecting both systems. You need to use a scan tool to access the chassis control system and read the diagnostic codes. There are definitely Diagnostic Trouble Codes stored when these lights are on. The code does not tell you what part to replace, but rather gives you a direction to go in diagnosing the cause of the problem.
Sep 21, 2013 | Cars & Trucks
Hp touchsmart 520 when i press the power button the blue light come on sound like it turning on but a blank black screen done this from new
Let it power on. If it plays the normal windows music then look very carefully at the screen. You may need a flash light. If you see a faint image then your inverter board or back light have burnt out. It will a small board 1 x 2 inches usually and have a small wire coming from the power supply and one going to the bottom or top of the screen.
Dec 29, 2012 | Computers & Internet
Install starter motor on 94 corrolla
the starter is located at the rear of the engine
diss connect the pos side of the battery
jack up the car and use jack stands for safety
with a light of flash light look up behind the motor from under the car
you will need a wrench size #12 metric for wire the other wire is just a
clip on
you will need a #14 wrench or socket for the bottom starter bolt
from the top of the engine drivers side look down to the starter bolt
you will need a # 14 wrenck to loosen and a socket #14 with a long extension
move wire harness out of you way just a little so you can get the socket on it have somone help you with this have your helper hold the starter from the bottom while you take out the bolt
when the starter is loose it will come out of that mess if you move to the right and pull the plastic guard to the side a little
Read more: http://wiki.answers.com/Q/How_to_you_remove_a_1994_Toyota_Corolla_starter#ixzz1m8HAzTeW
Feb 12, 2012 | 1994 Toyota Corolla
I've pressed the reset button because it was not turning on, it still does not turn on. instead water comes up through the disposal and into the sink.
try using a 1/4 allen wrench and manually turning the blades. there is usually a hole in the very bottom (on the outside, under the sink) of the unit where you can use the allen wrench to turn the blades. make sure the unit power is off before you do this. sounds like something is binding the blades.
Aug 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The tv goes to turn on then the green light come up then flashes then the red light comes on then the green agin it does this a few time then turns off at no time is there a picture or sound. thanks
Probably some bad capacitors in the power supply or inverter/RF circuitry for the back-lights.
look for electrolytics with the top bubbled up on them, or bulging plug at the bottom or leaking electrolyte...these caps all need to be replaced.
Feb 28, 2011 | LG 50PG20 50 in. Plasma HDTV
My bottom break light won't work. The top brake light works but neither bottom lights work. I've checked the fuse and replaced both bulbs but they still don't work. When I manually engage the brake pedal...
You may have a problem with the turn signal switch, as power comes out of that switch to power the brake lights, the high mounted brake light does not go through that switch.
Dec 22, 2010 | 2003 Ford Explorer
Lincoln ls 04 check enging light is coming on and wrench light
You will need a OBD2 code reader, that will give you a "trouble code" then that will tell you what direction to look in, for the problem.
May 24, 2010 | 2004 Lincoln LS
Bottom brake lights and hazard lights do not come on. All other lights work including top brake lights. Fuses and bulbs checked.
Check for power out of brake light switch by brake pedal. Of its faulty , the 3rd brake light will still work. Hope this helps
May 20, 2009 | 2000 GMC Yukon Denali
The same like everyone but know answers like everyone pw, hhd, power led
have a look on the techguys tab at pcworld.co.uk, you will be able to download the maual from there
Nov 13, 2008 | E-Machines eMachines T3830 PC Desktop
Invacare Pronto M51 Power Wheelchair Logo
728 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
