Question about Quasar HQ2082UH Air Conditioner
Not cooling HQ2082KH air conditioner purchased 5-20-98. Used only in summer months. Yesterday started not cooling. No ice buildup, filter has been cleaned. When increasing the cooling number we use to feel it kick in. Now it is not doing it. Air coming in is not cold but cool but very low cool.
    Problem Solver:
  • 12 Answers
It sounds to me like u have a gas leak.you shouldent run the a/c until it gets fixed reason being that the cold suction gas is used to cool the compressor windings.if u continue to to run it you may end up in more expenses:-)
Posted on Jul 07, 2010
Whats with norpole 12000 btu window air conditioners w/FO CODE,now all i have is a expensive fan!
they eventually do need serviced by a good repairman .freon leaks out .control boards fail etc .
Jul 18, 2016 | Filter Heating & Cooling
Have a pac L90 and behind the filter it develops ice buildup after running for about 1 hour. Cleaned filter but problem is still there. Have used this unit for about 2 years
I have the same problem and mine is the same age. I think it's low on freon but no one near me works on them so I'll never know for sure.
Jul 06, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Fan freezes up with ice in winter
They need air, do not cover it when in use.
If ti cools fine in summer then you just have a defrost problem.
Make sure the outdoor coil is clean.
If the coils are clean, then you have a bad defrost control.
In heat mode the unit should go into a timed or temp controlled defrost. If it is frosting up to the point of stopping the fan, in heat mode only, and otherwise operates properly, then its a bad defrost control.
It is reccomended that the defrost temp sensor be replaced at the same time the defrost control board is replaced. Some temp sensors are part of the board and not a seperate component, but not most.
Aug 19, 2009 | GE Zoneline AZ25E12D3B Air Conditioner
My room air conditionar is not blowing out cold air,please help
if the compressor is running then the refrigerant has leaked out and repairs on that are 140usd+ , check the warranty on it.
Phil
Jun 10, 2009 | Heating & Cooling
Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Jun 30, 2008 | Frigidaire FAH08EJ1 Air Conditioner
Maintance
Check for dust buildup on both hot & cold coils, including any filters. Clean as required. Power washing can be used, provided water is kept away from the fan motor & controls. Allow to dry thoroughly before using. Vacuum cleaning is also acceptable. Note than on some units, the hot coil will have dirt buildup on the inside of the coil.
Jun 21, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Cooling problem
Check your unit for dust buildup or blocked filters. Clean as required.
Jun 14, 2007 | Fujitsu 12C1 Air Conditioner
Quasar HQ2082UH Air Conditioner Logo
201 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
