Question about Sharp AF-R100DX Air Conditioner
Runs well in evening, during heat of midday shorts out.
During recent heat wave unit trips breaker ! never done this before.
about 10 years old. runs ok when evening comes around!
    Guru:
  • 1,524 Answers
Clean coils both inside and out. Then see what happens.
Posted on Jul 07, 2010
Ge double oven turns off during baking
WHEN THE RESISTOR EXPANDS UNDER INTENSE HEAT IT MAY BE TOUCHING GROUND AND TRIPPING THE BREAKER.
Jun 18, 2015 | GE Kitchen Ranges
AC trips circuit breaker not long after a recent power outage.
Sounds like your compressor is shorted to ground. If you are able, unhook compressor, wrap wires and restart. If breaker doesn't trip than u know.
Jun 07, 2017 | DeLonghi Heating & Cooling
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
OUr air conditioning system works well until the circuit breaker trips. We added another large return vent in the hall to try to get more air circulating and that didn't work. We just replaced the...
Current (amps) is voltage (volts) divided by resistance (ohms) or I=v/r. Breakers "trip" when there is too much current flowing through them. This can be caused by wiring that is too small for the application or a short (or a bad breaker, but since you just replaced that).
Cable Size:
The conductors have resistance and heat up when current runs through them. Properly sized conductors allow this heat to be dissipated. Long cable runs or cable runs which are tightly bundled with other cables can prevent this dissipation. Heat adds additional resistance which in turns causes more heat, eventually tripping the breaker to prevent a fire. For a 40 amp breaker, the cable should be a dedicated, 8 gauge wire.
Short:
A short (low impedance connection) can be between two conductors or between one conductor and ground (also called a ground fault). Shorts can be tough to track down when they are intermittent. This can be because the insulation was damaged (during installation, by rodents, etc). Moisture can deteriorate insulation or conductors.
It may only be present under certain conditions, so you can try this immediately following a trip. Shut both the breaker and the cutoff at the condenser (you want to isolate the cable), then use a meter to check for bleed between each of the conductors and each other conductor or ground. The neutral eventually connects to ground so it will have zero impedance. If you find there is a connection, you (or your electrician if you don't know what you're doing) will have to track it down and repair it.
It could be a clamp that is too tight where the line enters a jbox or panel, a staple that was driven too far and is biting into the insulation, a bend that is too tight, or a length that isn't supported well and subjected to vibration from a nearby motor .
Other possibilities:
At 40 Amps they'd be really expensive, but are you using a GFI or Arc-Fault breaker? Either of those could cause unwanted tripping.
Good luck with it.
jack g
Aug 06, 2010 | Heating & Cooling
Torpedo pump...I have one when I plug it in...it trips breaker
I had the exact same issue. I left mine out for the winter and when I plug it in, the breaker trips. My warranty was up so my friend took it apart. The seal had broken alowing water to leak into the bottom the pump where the wires connect to top of motor. This is supposed to be water free and is protected by several seals.
I am currenlty trying to put sealant where the cord goes into unit to stop water from going in. I will let you know how that works.
One tip my friend recommeded is to make sure there is no stress on the cord as it appears this seal is weak and and kind of stress will break it. hope this helps -- Rob
Apr 27, 2010 | RTO Cal Torpedo Pump 7500 Gph
I have the Kenmoore Microwave Hood 721.80402. During this last wave of storms, I was without power for 2 days. Once the power was restored, the microwave will not work. Everything is plugged in and the...
You might try pulling the plug on the unit and leaving it overnight. The electronics may have locked up due to irregular voltage during the failure. There may also be a GFI (ground fault interrupter) on that circuit that has tripped for the same reason. Check the kitchen outlets for a tripped GFI.
Feb 14, 2010 | Kenmore 62622 Microwave Oven
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
When turning on central air, our main electrical breaker is tripping. This is a brand new home barely over 1 year old. Should the AC have a warranty not covered by a builders contract??
Builders give a one year warranty but your air conditioner has five years on all parts. Anything outside the unit is not covered under the ac warranty. Breakers,stopped up drain and dirty coils.
Jun 09, 2009 | Weather King 10AJA6001AH Air Conditioner
Sharp AF-R100DX Air Conditioner Logo
50 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
