Question about Whirlpool LER4634J Electric Dryer
Heats but dryer drum won't go around
When I start the dryer it will heat but the drum won't turn.
    President:
  • 1,382 Answers
If the door switch or the door-switch actuator is defective, the dryer won't start and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either wont start.
Thank you !!
Posted on Jul 07, 2010
    President:
  • 1,430 Answers
This is likely the belt has broke. Here is a link that should help
http://appliancehelponline.com/dryerbeltvideo.html
Dryer won't spin
Someone is going to have to get inside to see if the belt (it should have one around the drum) is broken or the motor that drives it is seized, etc.
Need to see if drum turns and if too freely my money would be the belt.
Dec 05, 2012 | Whirlpool Dryers
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Oct 06, 2012 | Candy Dryers
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Drum still turns but no heat where do i find the heater
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
145 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
