Question about Cooktops
I need new knobs for collonial green creda gas hob tried internet 20 each can i use a cheaper black one. i need four
    President:
  • 1,891 Answers
You can use any knobs that fit the shafts/ creda is very expensive . robert shaw has replacment knobs . but make sure the shaft size is correct . if its gas the standard ( D ) style will work .. mm cost afout 19.00 for a set of 4 .. mm
Posted on Jul 22, 2010
New burner caps and hob knobs wanted for model 02-202110.\r\nthis model is obselete so what other make of gas hob is compatable.
Try calling http://www.selectappliance.com
  • Toll-Free: (888) 235-0431 (phone order hours: 9:00AM - 5:00PM Pacific time, Monday - Friday)
  • Phone: (650) 588-9100
  • Feb 03, 2011 | WindCrest 35 in. CTG365D Stainless Steel...
    Tip
    GAS KITCHEN APPLIANCE CLICKING SOUND
    Good Day,<br /><br />Have you ever had that problem with your Gas Hob, Stove or Cooktop where you hear a clicking the whole time, coming from <span style="font-weight: bold;">the ignition switches?</span> Well, then today I will show you how to <span style="font-weight: bold;">resolve the problem.</span><br /><br />Why does this happen? <span style="font-weight: bold;">Moisture</span> on the ignition switches... Be it because of you cleaning it obsessively or, because you might have had a small water spillage - the causes could be quite a few things <span style="font-weight: bold;">related to water.</span><br /><br />Now for the solution (Please note: I will be using a General Electric Stove & Hotpoint Hob as demonstration, but this solution should work for <span style="font-weight: bold;">most ranges - if not all</span>)<br /><br /><span style="font-weight: bold;">Step 1 (Safety first)</span><br /><br />Turn the machine off, switch it off at the mains if it is powered by it, and if powered by another source - Turn this off!<br /><br /><span style="font-weight: bold;">Step 2</span><br /><br />Remove the knobs of the Hob/Stove:<br /> <br /><img src="jedemeyer1_31.JPG" /><br /><br />If they do not come out, try to pull them as far out as possible, without breaking them. If there is a seal beneath them, then take it off as well - in the case if the knob does not come off, leave them be... If any grime or fat deposits are present, remove them with a damp cloth and some toothpicks.<br /><br /><span style="font-weight: bold;">Step 3</span><br /><br />Get a hairdryer, or fan.<br /><br /><span style="font-weight: bold;">If using the hairdryer:</span> <span style="font-style: italic;">Dry each knob area for 3 to 5 minutes for each knob respectively.</span><br /><br /><span style="font-weight: bold;">If using a fan:</span> <span style="font-style: italic;">Put the fan facing all the knobs, and leave it there for 30 minutes.</span><br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Step 4</span><br /><br />Leave the oven for <span style="font-style: italic;">about 20 minutes</span>, and then re-attach the knobs and seals and re-connect it to power.<br /><br />TEST, and viola! The problem is fixed.<br /><br />I have attached a video to this Tip, that shows a complete yet simple solution to this problem (Kindly provided by General Electric):<br /><br /><utube src="-vG9QQDiFCw"><br /><br />Now you can use your Hob/Cooktop/Stove with no more annoying clicking sounds.<br /><br />I hope this Tip has helped you, if it did - Please rate it.<br /><br />Kind Regards<br /><br />JEDEMEYER1<br />
    on Aug 03, 2011 | Cooktops
    Gas hob is permanently igniting
    hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
    tnx gerbee
    May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
    Miele KM 320 G gas cooktop ignitor
    I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
    To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
    Note: The 2-zone Wok Burner had a different control knob that the other burners.
    To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
    Disassembly
    Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
    In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
    Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
    Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
    To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
    Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
    Ignitor will not stop sparking on AEG Electrolux Cooker Hob
    gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
    Jan 09, 2009 | Cooktops
    Four burner gas hob
    You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
    Jan 04, 2009 | Cooktops
    Creda gas hob now keeps ignighting
    the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
    Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
    No gas to hobs
    use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
    Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
    Hob turns off
    hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
    Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
    Baumatic B40 Gas Hob : Gas not staying on.
    we have the same problem... try removing the knob, ours works fine without the knobs ????
    Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
    Cooktops Logo
    96 people viewed this question
    Top Cooktops Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Cooktop Expert? Answer questions, earn points and help others
